__debug__ always True
hlovatt
Post by hlovatt » Thu Aug 22, 2019 8:12 am
If I run:
import micropython
micropython.opt_level(3)
print('Opt level: {}, Debug: {}'.format(micropython.opt_level(), __debug__))
On:
MicroPython v1.11-167-g331c224e0 on 2019-07-21; PYBv1.1 with STM32F405RG
I get:
Opt level: 3, Debug: True
I was expecting 2 and above to set `__debug__ = False`.
Any idea what I'm doing wrong?
hlovatt
Re: __debug__ always True
Post by hlovatt » Thu Aug 22, 2019 8:22 am
Just noticed that it works if I type the code in at the REPL but not when run from the file system :(
Post by jimmo » Thu Aug 22, 2019 9:21 am
The behaviour of __debug__ is a bit subtle. It's handled by the lexer, so when __debug__ appears in your code, MicroPython effectively replaces it with True or False depending on the current value -- before executing any code. So setting opt_level in the same script won't change the value in the current script.
The documentation says "If *level* is given then this function sets the optimisation level for subsequent compilation of scripts"
Every line that you execute in the REPL is a new compilation.
If you want opt_level to take effect for your main.py, set it in boot.py.
hlovatt
Post by hlovatt » Fri Aug 23, 2019 2:28 am
Thanks, that explains what is going on. I didn't get any of the subtlety from the documentation! Thanks again.
