uPython syntax errors
Netrosec
Post by Netrosec » Mon Aug 26, 2019 3:47 pm
I use uPyCraft on a esp8266 board. I am working with an mqtt example for uPython i adapted to publish a simple message when light levels drops below a given threshold but i get this error:
exec(open(‘main.py’).read(),globals())
File “<stdin>”, line 1, in <module>
File “<string>”, line 43
SyntaxError: invalid syntax
Below is my main code.
from machine import Pin, ADC
from time import sleep
ldr = ADC(0)
def sub_cb(topic, msg):
  print((topic, msg))
if topic == b'notification' and msg == b'received':
  print('ESP received hello message')
def connect_and_subscribe():
  global client_id, mqtt_server, topic_sub
  client = MQTTClient(client_id, mqtt_server)
  client.set_callback(sub_cb)
  client.connect()
  client.subscribe(topic_sub)
  print('Connected to %s MQTT broker, subscribed to %s topic' % (mqtt_server, topic_sub))
  return client
def restart_and_reconnect():
  print('Failed to connect to MQTT broker. Reconnecting...')
  time.sleep(10)
  machine.reset()
  client = connect_and_subscribe()
except OSError as e:
  ldrValue = ldr.read()
  print(ldrValue)
  sleep(0.1)
if ldrValue >= 350
  msg = b'laser0 #%d' % counter
  client.publish(topic_pub, msg)
  last_message = time.time()
  counter += 1
Re: uPython syntax errors
Post by Roberthh » Mon Aug 26, 2019 4:04 pm
Please check what you posted. There is an except clause at the end without an matching try, and the indentation also seems wrong.
Netrosec
Post by Netrosec » Mon Aug 26, 2019 4:13 pm
OK, so i checked and pasted your edited code and the error stopped. But ldr does not give me a reading..
Netrosec
Post by Netrosec » Mon Aug 26, 2019 4:18 pm
Ooops. the error still persists.
Post by Roberthh » Mon Aug 26, 2019 5:09 pm
Please re-post your code.
Edit: it is usually better not to put your code in "main.py", but in a file with a different name which you then can import from REPL or main.py
Netrosec
Post by Netrosec » Mon Aug 26, 2019 5:13 pm
Advice well taken. But the problem isn't yet resolved.
Post by Roberthh » Mon Aug 26, 2019 5:28 pm
I still have the problem that what you posted is not well formatted python code, but that should give different error messages. Therefore i asked to re-post the code. The posting may have corrupted it.
Netrosec
Post by Netrosec » Mon Aug 26, 2019 5:55 pm
I understand that uPython uses 2 spaces indentation as opposed to regular python which uses 4 spaces indentation. I have fixed the formatting problem.
Post by Roberthh » Mon Aug 26, 2019 6:22 pm
UPython works like cPython with respect to indentation. You can use any number of spaces, as long as it is consistent in a level per block.
Post by pythoncoder » Tue Aug 27, 2019 7:15 am
It is also vital (in Python or MicroPython code) not to mix tabs and spaces. That leads to code which looks fine but won't work. Ensure your editor converts tabs to spaces.
