Simple scenario with button/IRQ/write to file that leads to ESP crash + FS coruption
cristian.spiescu
Post by cristian.spiescu » Sat Aug 31, 2019 8:07 pm
I have a very annoying problem that I discovered in the last phase of my project, when I replaced some "print()" with logging to a file. I have reduced the program to a very simple issue that illustrates the unwanted behavior:
1) I push a button
2) it's associated IRQ handler is triggered; I do "micropython.schedule()" for the actual handler
3) the actual handler writes something to a file
4) If I press the button a couple of times, then my ESP8266 reboots with the message:
NOTE: on the small program below, one needs to press rather quickly on the button in order to reproduce. On my big program, the issue was more immediate.
ets Jan 8 2013,rst cause:2, boot mode:(3,7)
load 0x40100000, len 31024, room 16
tail 0
chksum 0xb4
load 0x3ffe8000, len 1104, room 8
tail 8
chksum 0x74
load 0x3ffe8450, len 824, room 0
tail 8
chksum 0x45
csum 0x45
5) After reboot, a lot of strange entries appear on the file system:
>>> import os
>>> os.listdir()
['\x00\x00\x00\x00\x00\x00\x00\x00.\x00\x00\x00', '\x00\x00\x00\x00\x00\x00\x00\x00.\x00\x00\x00', '\x00\x00\x00\x00\x00\x00\x00\x00.\x00\x00\x00', ...
6) Some times the initial files still exist on the file system. But most of the time they disappear. And I need to reflash the ESP with the Micropython image.
A simple program that reproduces this behavior:
import uos, machine
import gc
gc.collect()
import micropython
pinRobinetButon = machine.Pin(13, machine.Pin.IN, machine.Pin.PULL_UP)
import utime
def irqHandler(pin):
micropython.schedule(sch, None)
def sch(p):
d = utime.localtime();
str = "a text"
str = "{:02d}:{:02d}:{:02d} {}".format(d[3], d[4], d[5], str);
print(str)
with open("logfile.0", "a+") as f:
f.write(str)
f.write("\n")
pinRobinetButon.irq(irqHandler, machine.Pin.IRQ_FALLING)
Is there something illegal that I'm doing in the above code? Or maybe have you got any other hints?
Thanks a lot in advance!
Best regards,
Cristian
ghayne
Re: Simple scenario with button/IRQ/write to file that leads to ESP crash + FS coruption
Post by ghayne » Sun Sep 01, 2019 8:21 pm
You are calling sch before it is defined!
JoeCharlieH
Post by JoeCharlieH » Sun Sep 01, 2019 10:37 pm
Well, beside the response above, you shouldn't do write operations inside an IRQ.
What I usually do is to change a variable inside the IRQ and check if it is True or False inside your main loop:
write_flag = False
	global write_flag
	write_flag = True
def sch():
str = "a text"
print(str)
	f.write(str)
	f.write("\n")
	if write_flag:
		irq_state = machine.disable_irq()
		write_flag = False
		sch()
		machine.enable_irq(irq_state)
Remember that IRQs must do fast operations that don't allocate memory.
More info in here.
Post by jimmo » Mon Sep 02, 2019 2:48 am
This is fine in Python. Think of it as the "module" executing first. It defines a global called "irqHandler", then a global called "sch".
Then later when irqHandler executes later, "sch" is in globals.
This is true in general, but:
- on ESP8266 pin IRQs are "soft" (i.e. they execute by the scheduler)
- the code posted uses micropython.schedule anyway, so the write code is definitely actually happening outside of irq context.
So, on ESP8266 the schedule() is actually unnecessary. And on other ports you can set the "hard=False" kwarg to Pin.irq() to make this happen automatically.
The actual issue here is that when the pin IRQ is enabled, the handler for it (written in C, part of hte micropython firmware) is in code that lives in flash. So if you're currently writing to the flash, it fails. i.e. it doesn't matter what you do in the irq handler, just registering it is enough to cause this issue. The correct solution for this is for C irq handlers to be stored in iram, but this is a bit tricky for MicroPython because lots of code would then have to live in iram.
This is also great advice in general, but unfortunately doesn't solve the issue here (your main loop could be writing when the interrupt fires).
So I think the only workaround you have is to disable irqs while writing to flash:
def sch(x):
    s = machine.disable_irq()
    with open('logfile.0', 'a+') as f:
        f.write(...)
    machine.enable_irq(s)
cristian.spiescu
Post by cristian.spiescu » Mon Sep 02, 2019 5:07 am
Thank you all for the replies.
W/ and w/o the schedule(): I got the impression that there was a difference. I.e. w/o schedule() it crashed faster. But maybe this is just a subjective impression.
I've tried to do that. I tried calling "machine.disable_irqs()" from REPL, after a fresh boot to see what it does; but the board reboots. This seems very strange.
cristian.spiescu
Post by cristian.spiescu » Mon Sep 02, 2019 5:17 am
UPDATE: calling "disable_irq()" messes somehow with the REPL + other things. The board doesn't accept my input for a few seconds, and then it reboots. Probably the watchdog timer.
BUT: using "disable_irq()" + "enable_irq()" in my code as suggested does the trick indeed.
Many thanks!
Post by jimmo » Mon Sep 02, 2019 9:30 am
Yep, you need IRQs enabled for most things to function (i.e. the repl needs to get notified that new characters are available), and yep you could be right that a watchdog is what's getting you here. I don't know much about ESP8266...
You should only disable IRQs for very short periods of time.
Glad it worked!
