Private const() variables aren't defined
cdwilson
Post by cdwilson » Wed Sep 11, 2019 4:51 pm
Can someone help me understand why private const() variables aren't defined?
>>> A = const(1)
>>> A
1
>>> _B = const(2)
>>> _B
NameError: name '_B' isn't defined
Re: Private const() variables aren't defined
Post by jimmo » Thu Sep 12, 2019 6:42 am
This is because you're running this in the REPL.
There's a neat optimisation that MicroPython does to save memory based on hte convention that variables starting with _ are "private". So they will only apply to the scope of the current module being compiled.
Each statement executed on the REPL kind of like making a file containing that statement and compiling it.
But yeah, it works if you access it inside the same module. e.g. if you had foo.py:
A = const(1)
_B = const(2)
print(A + _B)
that works just fine - the print will use _B correctly. If you run
import foo
print(foo.A) # fine
print(foo._B) # doesn't exist
This feature is really useful for drivers where you might have a whole list of consts (e.g. I2C register addresses) but no point having them hang around as variables. It was implemented in https://github.com/micropython/micropyt ... dc8edd5e0a likely based on Peter's suggestion in viewtopic.php?f=3&t=1941
Online
kevinkk525
Post by kevinkk525 » Thu Sep 12, 2019 6:46 am
That is the theory.
But in practice this is not true.
I do very often use this in my code (although it is wrong):
import foo
print(foo._private_variable)
And in the repl I can still use private variables, just not defined as const:
>>> _B="hi"
>>> _B
'hi'
>>> _C=const(3)
>>> _C
NameError: name '_C' isn't defined
Kevin Köck
Post by pythoncoder » Thu Sep 12, 2019 7:45 am
It seems to work as I'd expect. Consider foo.py
from micropython import const
_A = const(1)
_B = 2
C = 3
At the REPL
>>> from foo import *
>>> dir()
['const', '__name__', 'C']
Names with underscores are not exported. This is standard Python. Now try:
>>> import foo
>>> foo._A
AttributeError: 'module' object has no attribute '_A'
>>> foo._B
2
>>> foo.C
3
Python3 behaves similarly for _B and C (except that const is, of course, unsupported). The Python3 rule is that names beginning with an underscore are not imported when using from foo import *. They are available in foo's namespace - but as you say it's poor form to access them.
Online
kevinkk525
Post by kevinkk525 » Thu Sep 12, 2019 8:00 am
Ah sorry, I understood that part wrong. Thanks Peter.
In that regard it does work as expected.
I guess the initial question has been answered by jimmo however it is strange to me because why can I declare _B with a string but not with const (in repl)? Shouldn't the same explanation apply to this too? If _B="hi" works then I would expect it to work with const too.
>>> _B="hi"
>>> _B
'hi'
>>> _C=const(3)
>>> _C
Kevin Köck
Post by jimmo » Thu Sep 12, 2019 8:43 am
This optimisation exists purely to save memory - the const() variables starting with underscores don't even exist, their value just gets substituted at compile time.
But when you're not using const() (as in your _B="hi" example), the variable has to exist anyway, so maintaining cpython compatibility makes more sense. And as Peter showed, it does the right thing not showing up in dir().
Online
kevinkk525
Post by kevinkk525 » Thu Sep 12, 2019 9:01 am
I guess it makes sense although it is confusing in repl to have a different behaviour between const and strings.
Kevin Köck
cdwilson
Post by cdwilson » Thu Sep 12, 2019 9:59 pm
Thanks for the explanations!
I didn't realize this was how the REPL worked. For anyone else coming across this later, this example makes it pretty clear:
>>> _B = const(2)
>>> _B
>>> _B = const(2); _B
2
Post by pythoncoder » Fri Sep 13, 2019 6:40 am
The optimisation is important in device drivers where, for readability, you might want a lot of integer symbolic constants. This allows them to be used at zero cost (in RAM and in performance).
