pi@raspberrypi:~ $ picocom /dev/ttyUSB0 -b115200
picocom v3.1
port is : /dev/ttyUSB0
flowcontrol : none
baudrate is : 115200
parity is : none
databits are : 8
stopbits are : 1
escape is : C-a
local echo is : no
noinit is : no
noreset is : no
hangup is : no
nolock is : no
send_cmd is : sz -vv
receive_cmd is : rz -vv -E
imap is :
omap is :
emap is : crcrlf,delbs,
logfile is : none
initstring : none
exit_after is : not set
exit is : no
Type [C-a] [C-h] to see available commands
Terminal ready
When I hit the keyboard nothing happens. This is the same with either a NodeMcu and a ESP-01 connected to a Raspi 3. EraseFlash and write_flash do not give a bad prompt beforehand.
Any Idea?
many thanks in advance!!
picocom doesn't work
Re: picocom doesn't work
What device are you trying to connect to? The pyboards show up as /dev/ttyACM0 and not ttyUSB0. Make sure that there isn't some other program running which is using the same port (EDIT: I see that you're connecting to an ESP device, so this comment probably isn't relevant)
You can use the lsof command to see if any other process has the port open:
Also make sure that you're using a USB cable with data pins. Some USB cables are "charge only" and only provide power, and don't connect up the data lines.
$ lsof | grep /dev/ttyUSB0
Thanks for the tips. Since I do not want to appear rude, here is a short sign of life from me.
I have already had many hours of "blood, sweat and tears" behind me. The cable is okay. The power supply as a problem I cannot exclude. Other running programs also not.
I will continue to try and then announce myself. Thank you very much!
The other possibility is that picocom is working fine and that the MCU hasn't been flashed with micropython properly.
Can you show the full commands as well the output of erase_flash and write_flash?
