I am trying to get the minimal port of uPython to run on the Arm cortex-a53 cpu. I so far have switched the compiler and linker to use the arm tools gcc-arm-aarch64-elf. I have also changed mp_int_t and mp_uint_t to be 64 bit values from this post: viewtopic.php?p=29374#p29379
Yet when I run make, the elf file seems to be completely empty. Can anyone point out what else I am missing?
Thank you
Help Porting minimal to aarch64 armv8
Re: Help Porting minimal to aarch64 armv8
Can I get some more information about what you've done?
Which version and distribution of aarch64-gcc are you using?
Did you set CROSS=1
Did you change CFLAGS_CORTEX_M4 with the relevant settings for a53?
What do you mean by the elf was empty? Like actually a zero byte file?
Did you set CROSS=1
Hi jimmo,
1. In addition to changing flags in the Makefile, I made the following changes to mpconfigport.h:
--- a/ports/minimal/mpconfigport.h
+++ b/ports/minimal/mpconfigport.h
@@ -7,6 +7,8 @@
+#define MICROPY_OBJ_REPR (MICROPY_OBJ_REPR_D)
+#define MICROPY_NLR_SETJMP (1)
@@ -20,7 +22,7 @@
-#define MICROPY_ENABLE_GC (1)
+#define MICROPY_ENABLE_GC (0)
@@ -66,12 +68,12 @@
-#define UINT_FMT "%u"
-#define INT_FMT "%d"
-typedef int mp_int_t; // must be pointer size
-typedef unsigned mp_uint_t; // must be pointer size
+#define UINT_FMT "%lu"
+#define INT_FMT "%ld"
+typedef int64_t mp_int_t; // must be pointer size
+typedef uint64_t mp_uint_t; // must be pointer size
-typedef long mp_off_t;
+typedef long long mp_off_t;
2. I am using CROSS_COMPILE = ~/gcc-arm-8.3-2019.03-x86_64-aarch64-elf/bin/aarch64-elf-
3. I did set CROSS=1
4. I am using the following for CFLAGS:
CFLAGS_CORTEX_A53 = -mcpu=cortex-a53 -fsingle-precision-constant -Wdouble-promotion
CFLAGS = $(INC) -Wall -Werror -std=c99 -nostdlib $(CFLAGS_CORTEX_A53) $(COPT)
5. The elf file was not a zero byte file but the sections were all empty: text, data, bss, etc.
Side note: when I run "file build/firmware.elf" it says there is a corrupted program header...
@@ -7,6 +7,8 @@
@@ -20,7 +22,7 @@
@@ -66,12 +68,12 @@
