Frozen Modules based on board
seemefirst@gamil.com
Post by seemefirst@gamil.com » Wed Sep 25, 2019 6:05 pm
I was wondering if there is a way to include frozen files based on board. I am doing this on stm32 port. My understanding is that anything put in the ../ports/stm32/modules folder will be packed as frozen regardless of what board is compiled for. For example is there anyway to set the path for frozen modules in the board related configuration file/folder?
Re: Frozen Modules based on board
Post by dhylands » Wed Sep 25, 2019 8:03 pm
When you build your firmware image you can do:
make BOARD=SOMEBOARD FROZEN_MPY_DIR=/path/to/some/directory
and this will override the use of the modules subdirectory.
Post by seemefirst@gamil.com » Wed Sep 25, 2019 8:12 pm
Great Thanks,
Post by jimmo » Wed Sep 25, 2019 10:53 pm
You can also put FROZEN_MPY_DIR in your board-specific mpconfigboard.mk
This works well on STM32 because the default frozen modules are not required for board functioning, but on ESP32 you can't override the default ones. If you're interested, see https://github.com/micropython/micropython/pull/5084 for some early steps towards a future direction for additional board-level configuration of included resources.
