I assumed I can't use CTS/RTS if MicroPython also supports it. How did you use it? I don't see any reference to CTS/RTS in Ampy code: https://github.com/scientifichackers/am ... rd.py#L133stanely wrote: ↑Sun Mar 01, 2020 2:18 pmThis is probably off topic from this thread, but are you using flow control when communicating to MicroPython targets? I'm using Ampy and esptool at crazy fast baud rates without any issues, ever. I can't imagine all of that would work reliably without use of CTS/RTS flow control.
My IDE configuration using Notepad++, ampy and Tera Term
- aivarannamaa
Re: My IDE configuration using Notepad++, ampy and Tera Term
Aivar Annamaa
https://thonny.org
https://thonny.org
You're right, I see no mention of flow control. I don't know. Does this happen mostly when you're receiving or sending data?aivarannamaa wrote: ↑Sun Mar 01, 2020 2:53 pmI assumed I can't use CTS/RTS if MicroPython also supports it. How did you use it? I don't see any reference to CTS/RTS in Ampy code: https://github.com/scientifichackers/am ... rd.py#L133stanely wrote: ↑Sun Mar 01, 2020 2:18 pmThis is probably off topic from this thread, but are you using flow control when communicating to MicroPython targets? I'm using Ampy and esptool at crazy fast baud rates without any issues, ever. I can't imagine all of that would work reliably without use of CTS/RTS flow control.
- aivarannamaa
I don't know, it is not clear from the reports.
Aivar Annamaa
https://thonny.org
https://thonny.org
I get bouts of ampy complaining that it cannot enter raw REPL on the ESP8266. I say bouts because sometimes it's fine but after a while it starts to act up. I tried out the ESP32 and the problem became almost constant. I delved into the ampy module "pyboard.py" and noticed that the code made just one attempt at entering raw REPL with a 2 CTRL-C's followed by a CTRL-A. I changed the code to do multiple retries.
The original looks like this starting at line 184:
Made the following change:
Ampy now gets the raw REPL everytime on the ESP32, will have to monitor its performance with ESP8266 over a period of time because as I said it was working a lot of the time.
while n > 0:
self.serial.read(n)
n = self.serial.inWaiting()
self.serial.write(b'\r\x01') # ctrl-A: enter raw REPL
data = self.read_until(1, b'raw REPL; CTRL-B to exit\r\n>')
if not data.endswith(b'raw REPL; CTRL-B to exit\r\n>'):
print(data)
raise PyboardError('could not enter raw repl')
while n > 0:
self.serial.read(n)
for retries in range(0, 8):
self.serial.write(b'\r\x03\x03')
time.sleep(.1)
data = self.read_until(1, b'raw REPL; CTRL-B to exit\r\n>', .2)
if data.endswith(b'raw REPL; CTRL-B to exit\r\n>'):
break
print (retries)
print(data)
Paul Mulvey
Yeah - I had to make a similar change to rshell to get it working more reliably on ESP8266 and ESP32.
rshell sends a Control-C every 100 milliseconds until it gets a >>> before continuing with pyboard.py.
The reason is that the boards can take a while before micropython starts up, and with some boards, opening the serial port causes the board to reset, and the startup delay then pushes the micrpython start beyond where pyboard.py expects the Control-C's to work.
I'm using Thonny and are happy most of the time, especially because I haven't found so much alternative IDEs. Thank you for your work on this!!!
One question: is there a way to get auto completion?
Sometimes the serial connection to the boards and the access to the filesystems seems to be buggy.
For example:
- when I open files directly on the device the below window of thonnys shows all files and the connection is broken.
- I have to reconnect the cable and press the start/stop button
--> I can prevent this by doing the following after connect the device with Thonny:
- in the repl console:
-> import os
-> os.listdir()
Sounds crazy I know but works for me...
Im using TTGO boards with Wrover and Wroom Chips of ESP32 (TTGO T-Energy T18 / ESP-WROOM-32 ESP-32s). It is everytime the same experiences. I also tried to update my windows 10 drivers but without success.
If you are interested I can try to help you to find and debug this issues...
Greetings!
For example:
-> import os
-> os.listdir()
Greetings!
- aivarannamaa
Sure! Please copy your issue and workaround to https://github.com/thonny/thonny/issues
I have started refactoring the MicroPython part of Thonny. Hopefully next version will be more reliable.
Code completion can be invoked with Ctrl+Space, but at the moment you can't have it automatically (https://github.com/thonny/thonny/issues/625)
Aivar Annamaa
https://thonny.org
https://thonny.org
With my code on the ESP8266 getting bigger by the day I was now running into the "memory allocation" errors. Having pulled out all of my hair and exposing skull bone I think that I have a solution. For some reason I have only now discovered the simple way to use mpy_cross [https://pypi.org/project/mpy-cross/] rather than using VMs on windows etc. Just install it as per PyPi. I have now modified the Notepad++ NppExec script as follows and added more comments and everything is working... so far! Someone out there will tell me what horrible mistakes I am making, but for now all is good. My project has been extended now from an educational development board for ESP8266 to include an expansion IO board. On this board I have 4 Arduinos as I2C slaves on the same bus, all running identical programs. They set their individual I2C addresses by reading their own analogue port which has different resistor dividers. I just throw commands at them from the ESP to carry out all sorts of IO (Read/Write/Servo/PWM/IR etc). Speed-wise I can get a 900Hz output on the Arduino having sent On/Off commands and having them processed by a command handler on the Arduinos. I can only make 600Hz with the python code on the dev board addressing the board's own PCF8574 chips! I'm including a photo of the work in progress, I'm making great progress thanks to Covid-19... silver lining etc!
Notepad++ NppExec script:
// disable output to the Console
NPP_CONSOLE -
set port = COM4
// Set this variable to point at the path to python
set PyPath = C:\Users\Me\AppData\Local\Programs\Python\Python38-32\
set PyExec = $(PyPath)python.exe
// make sure we are in the directory of the file we are editing
cd $(CURRENT_DIRECTORY)
// check and see if this is the folder that has the boot.py file in it
// because the folder below this is Globals and this script runs differently
// for the file there where all of my library file are
// capture the output of the next command in $(OUTPUTL) variable
npe_console v+
cmd /c if exist "boot.py" echo Exists
npe_console v-
if "$(OUTPUTL)" = "Exists"
// the boot.py file is here so we know that the edited file is in the workspace folder
// save this file first
NPP_SAVE
// step up one folder to get at the DisTeraTerm.py script
// DisTeraTerm finds the TeraTerm app and sends key strokes to it to disconnect the COM port
cd..
// show results of DisTeraTerm and ampy on the console
NPP_CONSOLE +
$(PyExec) DisTeraTerm.py $(port)
// now send the file to the device using ampy
$(PyPath)scripts\ampy --port $(port) put $(FULL_CURRENT_PATH)
// File is downloaded so we send a CTRL-D to the device for a soft reboot
$(PyExec) SendCTRLD.py $(port)
// Reconnect TeraTerm to COM port
$(PyExec) ConTeraTerm.py
else
// this file is not in the workspace folder, must be in Globals
NPP_SAVE
// need to step up twice to get at DisTeraTerm
cd..
cd..
NPP_CONSOLE +
// every file in the Globals folder will be cross-compiled first
// as it is assumed to be a library file and removes the need for the device
// to compile it which causes "memory allocation" errors sometimes
$(PyExec) -m mpy_cross $(FULL_CURRENT_PATH)
// for some reason ampy was not running with the newly created .mpy file
// I stuck in a delay of 300ms as a temporary kludge
sleep 300
// this ampy line is different from the previous one because I had to
// build the name of the file with the .mpy extension rather than use $(FULL_CURRENT_PATH)
// also the file needs to be put into the Globals folder on the device
$(PyPath)scripts\ampy --port $(port) put $(CURRENT_DIRECTORY)\$(NAME_PART).MPY \Globals\$(NAME_PART).MPY
NPP_CONSOLE +
exit
echo No
- 20200331_091159.jpg (254.1 KiB) Viewed 5433 times
Paul Mulvey
Alternative Updated
All of this discussion on IDEs has inspired me to work on some improvement for the tool I use.
https://github.com/joewez/AmpyFileManager
It's an editor wrapped around the ampy utility with a few extra features to make life easier. .
I downloaded the zipped binary but it will not connect to my ESP8266. Refresh seems to be doing something but nothing appears. I edited the xml file to launch my TeraTerm:
I just get Invalid Host from TeraTerm.
<add key="TerminalApp" value="C:\Program Files (x86)\TeraTerm\ttermpro.exe"/>
<add key="TerminalAppArgs" value="-serial COM4"/>
Paul Mulvey
