Properly checking for errors during a WiFi connection?
kevinkk525
Re: Properly checking for errors during a WiFi connection?
Post by kevinkk525 » Fri Jan 31, 2020 2:38 pm
you import network so STAT_NO_AP_FOUND is not defined in global space but in network.
Therefore you have to check against "network.STAT_NO_AP_FOUND" or do "from network import *"
Kevin Köck
tll
Post by tll » Sat Feb 08, 2020 7:53 pm
I am not sure if this will be of any help... I wonder if looking at both, the espressif and MP source modules you may be able to figure out what is handled and any mappings...
For example, this is from esp_wifi.h
[size=85][size=50][size=50]
[size=50][/size]#define ESP_ERR_WIFI_NOT_INIT    (ESP_ERR_WIFI_BASE + 1)   /*!< WiFi driver was not installed by esp_wifi_init */
#define ESP_ERR_WIFI_NOT_STARTED (ESP_ERR_WIFI_BASE + 2)   /*!< WiFi driver was not started by esp_wifi_start */
#define ESP_ERR_WIFI_NOT_STOPPED (ESP_ERR_WIFI_BASE + 3)   /*!< WiFi driver was not stopped by esp_wifi_stop */
#define ESP_ERR_WIFI_IF          (ESP_ERR_WIFI_BASE + 4)   /*!< WiFi interface error */
#define ESP_ERR_WIFI_MODE        (ESP_ERR_WIFI_BASE + 5)   /*!< WiFi mode error */
#define ESP_ERR_WIFI_STATE       (ESP_ERR_WIFI_BASE + 6)   /*!< WiFi internal state error */
#define ESP_ERR_WIFI_CONN        (ESP_ERR_WIFI_BASE + 7)   /*!< WiFi internal control block of station or soft-AP error */
#define ESP_ERR_WIFI_NVS         (ESP_ERR_WIFI_BASE + 8)   /*!< WiFi internal NVS module error */
#define ESP_ERR_WIFI_MAC         (ESP_ERR_WIFI_BASE + 9)   /*!< MAC address is invalid */
#define ESP_ERR_WIFI_SSID        (ESP_ERR_WIFI_BASE + 10)   /*!< SSID is invalid */
#define ESP_ERR_WIFI_PASSWORD    (ESP_ERR_WIFI_BASE + 11)  /*!< Password is invalid */
#define ESP_ERR_WIFI_TIMEOUT     (ESP_ERR_WIFI_BASE + 12)  /*!< Timeout error */
#define ESP_ERR_WIFI_WAKE_FAIL   (ESP_ERR_WIFI_BASE + 13)  /*!< WiFi is in sleep state(RF closed) and wakeup fail */
#define ESP_ERR_WIFI_WOULD_BLOCK (ESP_ERR_WIFI_BASE + 14)  /*!< The caller would block */
#define ESP_ERR_WIFI_NOT_CONNECT (ESP_ERR_WIFI_BASE + 15)  /*!< Station still in disconnect status */[/size][/size][/size]
and in esp_err.h
#define ESP_ERR_WIFI_BASE           0x3000  /*!< Starting number of WiFi error codes */
