Page 1 of 2
waiting for an interrupt flag to be set
Posted: Tue Nov 05, 2019 3:19 am
by devnull
This seems to work erratically for me.
In an ISR, I set a boolean Flag, i.e. self.connected, and then in a function I tight-loop waiting for this flag to be set:
While not self.connected:
pass
do something when connected
Now sometimes this works, and sometimes it does not, is there any way to do this reliably ??
Re: waiting for an interrupt flag to be set
Posted: Tue Nov 05, 2019 3:51 am
by devnull
If the function is reading the value of self.connected inside the tight loop when self.connected is being modified by the interrupt will this cause problems ??
Posted: Tue Nov 05, 2019 4:09 am
by jimmo
Can you share more example code?
What sort of interrupt? e.g. hard (stm32 pin), soft (esp32 pin, BLE, etc)?
Posted: Tue Nov 05, 2019 4:13 am
by devnull
Well Jimmo, in this case it is part of the Peripheral class that you kindly provided me with:
Class Peripheral:
def connect(self,mswait=2000):
if not self._connected:
self._central._connecting_peripherals[(self._addr_type, self._addr)] = self
self._central._ble.gap_connect(self._addr_type, self._addr)
now = time.ticks_ms()
while time.ticks_diff(time.ticks_ms(),now) < mswait:
if self._connected: break
return self._connected
## Central Interrupt - Called
def connected(self):
self._connected = True
What I am trying to achieve is an async connect !
Posted: Tue Nov 05, 2019 4:29 am
by devnull
Now I am thinking that it might be that the device is not connecting and that it's nothing to do with the interrupt, but generically speaking if you modify a variable in an ISR and then in a loop read the value, could this be an issue ??
Posted: Tue Nov 05, 2019 9:08 am
by jimmo
devnull wrote: ↑Tue Nov 05, 2019 4:13 am
Technically that's a synchronous connect, but yes, definitely useful!
I would like to make a properly asyncio-based wrapper around the low-level API, so you can have the best of both worlds.
Anyway, what you're doing is fine -- modifying a value from an ISR and reading it outside the ISR is fine - and is a very common thing to do.
Posted: Tue Nov 05, 2019 11:17 pm
by devnull
@jimmo - I have just discovered on the Pyboard D, that sometimes it receives a disconnect interrupt for connection handle 65535, even though a connection for this handle was never opened.
It then appears that the next connect attempt will fail.
Any idea what this is ???
Posted: Wed Nov 06, 2019 9:19 am
by devnull
I need for this to be bullet proof as it will be running un-manned.
I am getting a lot of disconnect interrupts with handle 65535 and this then appears to kill the next connection.
This loop is simply stress testing, and I get the 65535 handle VERY frequently !
h1 = j.Dev(b"\xcb\xd0\xc5\x0c'\xbd")
h1.connect()
time.sleep(1)
h1.disconnect()
time.sleep(1)
Trap the 65535 handle...
if event == _IRQ_PERIPHERAL_DISCONNECT:
if data[0] == 65535:
return print('@@@ERROR')
connected 64
True
True
disconnected 64
connected 64
True
True
disconnected 64
connected 64
True
True
disconnected 64
@@@ERROR
False
False
connected 64
True
True
disconnected 64
connected 64
Posted: Wed Nov 06, 2019 9:23 am
by jimmo
Ok thanks for the details, I will investigate!
Posted: Wed Nov 06, 2019 9:49 am
by devnull
Jimmo, I can work around this by setting a error flag and if the flag is set and connection fails, then clear the flag and retry the connection.
This prevents the connection failure but wastes time attempting the connection twice, and it only appears to happen on the first connection after the error.
I think that 65535 might be the handle that is reported, when a response is received from a device that was connected in a previous session but no longer has an active connection in the current session ?.
It would be useful if you could query BLE for a list of it's connection handles
