littlefs - advantages & disadvantages
jedie
Re: littlefs - advantages & disadvantages
Post by jedie » Fri Dec 06, 2019 12:58 pm
I now see, that LittleFS will be the default in MicroPython v2.0, see: https://github.com/micropython/micropython/issues/4821 :D
Question: It there a way to detect, if the filesystem is already converted to LittleFS?
jedie
Post by jedie » Fri Dec 06, 2019 2:34 pm
Think i found a way:
import flashbdev
import uos as os
uname = os.uname()
print(uname.machine, uname.release)
print('MicroPython', uname.version)
print()
print('flashbdev.size....:', flashbdev.size)
print('reserved sectors..:', flashbdev.bdev.RESERVED_SECS)
print('start sector......:', flashbdev.bdev.START_SEC)
print('sector size.......:', flashbdev.bdev.SEC_SIZE)
print('num blocks........:', flashbdev.bdev.NUM_BLK)
def filesystem_hex_dump(line_count=10, chunk_size=16):
    buf = bytearray(chunk_size)
    for block_num in range(line_count):
        offset = block_num * chunk_size
        print('%04x - %04x' % (offset, offset + chunk_size - 1), end=' - ')
        flashbdev.bdev.readblocks(block_num, buf)
        print(' '.join('%02x' % char for char in buf), end=' - ')
        print(''.join(chr(char) if 32 < char < 177 else '.' for char in buf))
ESP module with ESP8266 2.2.0-dev(9422289)
MicroPython v1.11-8-g48dcbbe60 on 2019-05-29
flashbdev.size....: 1048576
reserved sectors..: 1
start sector......: 153
sector size.......: 4096
num blocks........: 106
0000 - 000f - eb fe 90 4d 53 44 4f 53 35 2e 30 00 10 01 01 00 - ..MSDOS5.0.....
0010 - 001f - f8 ff ff 00 f0 ff ff 0f 00 ff 0f 00 ff ff ff ff - ................
0020 - 002f - 42 4f 4f 54 20 20 20 20 50 59 20 20 18 00 51 b6 - BOOT....PY....Q.
0030 - 003f - e5 41 54 43 48 44 4f 47 4d 50 59 20 18 00 19 86 - .ATCHDOGMPY....†
0040 - 004f - 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 - ................
0050 - 005f - 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 - ................
0060 - 006f - 4d 04 02 1f 20 82 00 03 00 30 00 00 00 07 07 00 - M....‚...0......
0070 - 007f - 4d 04 02 1f 20 84 28 08 00 00 00 00 00 07 07 00 - M....„(.........
0080 - 008f - 4d 04 02 1f 20 81 04 02 00 30 00 00 00 07 07 00 - M.......0......
0090 - 009f - 4d 04 02 1f 20 81 14 02 00 30 00 00 00 07 07 00 - M.......0......
MSDOS5.0 -> FAT, isn't it?
So, it's possible to made this:
def detect_filesystem():
    buf = bytearray(8)
    flashbdev.bdev.readblocks(0, buf)
    if buf[3:8] == b'MSDOS':
        return 'FAT'
    return 'unknown'
print(detect_filesystem())
Is it maybe sufficient to check only the first one or two bytes?
EDIT: No: The first 3 bytes are the "jump address" -> https://en.wikipedia.org/wiki/Design_of ... oot_Sector
EDIT: Boring: I can't convert to littlefs1 or littlefs2:
os.VfsLfs.mkfs(flashbdev.bdev) # AttributeError: 'module' object has no attribute 'VfsLfs'
os.VfsLfs2.mkfs(flashbdev.bdev) # AttributeError: 'module' object has no attribute 'VfsLfs2'
EDIT2: Create a issue -> https://github.com/micropython/micropython/issues/5387
kevinkk525
Post by kevinkk525 » Fri Dec 06, 2019 3:15 pm
You are using an old firmware build, pull the latest changes and build it again. littleFS will be included.
Kevin Köck
jedie
Post by jedie » Fri Dec 06, 2019 3:50 pm
I used the last stable build from: http://micropython.org/download#esp8266
So the feature does only exists in the "daily builds" ?
Are daily build "stable" ?
Why contains the official docs stuff that are in last stable builds?!?
kevinkk525
Post by kevinkk525 » Fri Dec 06, 2019 4:22 pm
you can use the daily builds, it's basically what I use when building the firmware myself. They are stable.
Kevin Köck
jedie
Post by jedie » Fri Dec 06, 2019 6:37 pm
I flash the initial OTA esp8266-ota-20191206-v1.11-624-g210d05328.bin and the filesystem looks strange:
ESP module with ESP8266 2.0.0(5a875ba)
MicroPython v1.11-624-g210d05328 on 2019-12-06
start sector......: 213
0000 - 000f - 4d 04 02 1f 20 82 58 03 00 30 00 00 00 07 07 00 - M....‚X..0......
0010 - 001f - 4d 04 02 1f 20 84 64 04 00 30 00 00 00 07 07 00 - M....„d..0......
0020 - 002f - 4d 04 02 1f 20 83 40 04 00 30 00 00 00 07 07 00 - M....ƒ@..0......
0030 - 003f - 4d 04 02 1f 20 81 4c 03 00 30 00 00 00 07 07 00 - M....L..0......
0040 - 004f - 4d 04 02 1f 20 84 2c 03 00 30 00 00 00 07 07 00 - M....„,..0......
After os.VfsFat.mkfs(flashbdev.bdev)
0010 - 001f - f8 ff ff 00 00 00 00 00 00 00 00 00 00 00 00 00 - ................
0020 - 002f - 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 - ................
0030 - 003f - 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 - ................
But again: AttributeError: 'module' object has no attribute 'VfsLfs2'
EDIT: I used the latest non-OTA build: esp8266-20191206-v1.11-624-g210d05328.bin
Get interesting message after boot:
The FAT filesystem starting at sector 153 with size 98 sectors appears to
be corrupted. If you had important data there, you may want to make a flash
snapshot to try to recover it. Otherwise, perform factory reprogramming
of MicroPython firmware (completely erase flash, followed by firmware
programming).
I run my script again:
0000 - 000f - 01 00 00 00 30 34 c0 39 12 0d f0 00 ee 07 2c 40 - ....04.9......,@
0010 - 001f - 39 12 3c f3 37 92 02 86 ad 00 5c b3 37 92 02 86 - 9.<.7’.†­.\.7’.†
0020 - 002f - 12 c1 10 0d f0 00 00 00 c6 31 2c 40 8a 31 2c 40 - .........1,@Š1,@
0030 - 003f - 7a e1 da f7 d8 0f e8 0e 00 46 40 30 f3 81 da ee - z........F@0...
0040 - 004f - c7 f8 30 30 f4 d8 51 88 81 98 91 c0 c0 f4 0c 04 - ..00..Qˆ˜‘.....
Detected filesystem: unknown
convert to FAT...
Detected filesystem: FAT
convert to littlefs2...
  File "<stdin>", line 58, in <module>
EDIT: Just for completeness. With a "erase_flash" and fresh flash, it looks:
0010 - 001f - f8 ff ff ff 0f 00 00 00 00 00 00 00 00 00 00 00 - ................
0020 - 002f - 42 4f 4f 54 20 20 20 20 50 59 20 20 18 00 01 00 - BOOT....PY......
jedie
Post by jedie » Fri Dec 06, 2019 7:15 pm
Is that right? I guess I'm out of luck.
In the last daily build esp8266-20191206-v1.11-624-g210d05328.bin is no 'uasyncio' -> https://github.com/micropython/micropython/issues/5390
Christian Walther
Post by Christian Walther » Fri Dec 06, 2019 8:56 pm
As far as I can see, littlefs is not enabled by default for ESP8266, you need to explicitly build with MICROPY_VFS_LFS2=1.
Apparently the daily builds are made with the default manifest rather than the release manifest and therefore don’t have as many frozen modules as the stable releases. I’m not sure what the standard way of changing that is, I’m guessing FROZEN_MANIFEST=boards/manifest_release.py.
Both of these together don’t seem to fit with the current linker script, I get
xtensa-lx106-elf-ld: build-GENERIC/firmware.elf section `.irom0.text' will not fit in region `irom0_0_seg'
xtensa-lx106-elf-ld: region `irom0_0_seg' overflowed by 13344 bytes
Post by pythoncoder » Sat Dec 07, 2019 8:52 am
There are a few "wrinkles" in doing this stuff. If you have too many frozen modules you need to allocate more space. Modify esp8266/boards/esp8266.ld so that line 8 reads:
    irom0_0_seg :  org = 0x40209000, len = 0xa7000
You can specify any location for frozen files. The manifest file does this. Mine reads
freeze('/mnt/qnap2/Scripts/modules/esp8266_modules')
freeze('$(MPY_DIR)/tools', ('upip.py', 'upip_utarfile.py'))
freeze('$(MPY_DIR)/drivers/dht', 'dht.py')
freeze('$(MPY_DIR)/drivers/onewire')
The file /mnt/qnap2/Scripts/modules/esp8266_modules contains symlinks to modules for freezing.
I build ESP8266 firmware with this script, which points to the above manifest file and specifies littlefs2. Obviously directories will need changing:
#! /bin/bash
cd /mnt/qnap2/data/Projects/MicroPython/micropython/ports/esp8266
MANIFEST='/mnt/qnap2/Scripts/manifests/esp8266_manifest.py'
if [ $# -eq 1 ] && [ $1 = "--clean" ]
then
    make clean
fi
if [ $# -eq 1 ] && [ $1 = "--erase" ]
then
    make clean
    esptool.py  --port /dev/ttyUSB0 erase_flash
fi
if make -j 8 FROZEN_MANIFEST=$MANIFEST MICROPY_VFS_LFS2=1
then
    sleep 1
    esptool.py --port /dev/ttyUSB0 --baud 115200 write_flash --flash_size=detect -fm dio 0 build-GENERIC/firmware-combined.bin
    cd -
    sleep 4
    rshell -p /dev/ttyUSB0 --editor nano --buffer-size=30
else
    echo Build failure
fi
cd -
Lastly, as @kevinkk525 has explained, to force a format to littlefs you need to edit inisetup.py (in your frozen directory):
    uos.VfsLfs2.mkfs(bdev)
    vfs = uos.VfsLfs2(bdev)
#    uos.VfsFat.mkfs(bdev)
#    vfs = uos.VfsFat(bdev)
Erase flash, compile, load and enjoy.
I now have a ~600LOC program running with 25.1KiB of free RAM...
jedie
Post by jedie » Sat Dec 07, 2019 9:00 am
It all seems to me that it's not finished yet.
I still shy away from the effort to compile the firmware myself.
I hope the next stable version will be released soon and has littlefs2 directly on board. (Because daily builds lacking 'uasyncio', too, see: https://github.com/micropython/micropython/issues/5390 )
