dim LEDs
jedie
dim LEDs
Post by jedie » Thu Dec 19, 2019 10:28 am
I would like to dim the power LED on my Sonoff devices, because it's very bright.
I created this:
import utime
class Led:
    def __init__(self, name, pin, on, off):
        self.name = name
        self.pin = pin
        self._on = on
        self._off = off
    def on(self):
        self.pin.value(self._on)
    def off(self):
        self.pin.value(self._off)
    def toggle(self):
        if self.is_on:
            self.off()
            self.on()
    def flash(self, sleep=0.5, count=5):
        was_on = self.is_on
        for no in range(count):
            self.toggle()
            utime.sleep(sleep)
        if was_on:
            self.on()
            self.off()
    @property
    def is_on(self):
        return self.pin.value() == self._on
    @property
    def state(self):
        return 'ON' if self.is_on else 'OFF'
    def __str__(self):
        return '%s %s: %s' % (self.name, self.pin, self.state)
class PwmLed(Led):
    def __init__(self, *args, **kwargs):
        super().__init__(*args, **kwargs)
        self.dim_duty = (None, 600, 800, 950)
        self.dim_max_level = len(self.dim_duty)  # Dimming down to the maximum
        self.current_dim_value = None  # Full ON
    def set_dim_level(self, dim_level):
        if not 0 <= dim_level <= self.dim_max_level:
            print(
                'ERROR: level %r is not between 0 and %i' % (dim_level, self.dim_max_level)
            dim_level = self.dim_max_level
        self.current_dim_value = self.dim_duty[dim_level]
    def on(self):
        self.deinit_pwm()
        if self.current_dim_value is None:
            # turn full ON
            super().on()
            machine.PWM(self.pin, freq=100, duty=self.current_dim_value)
    def off(self):
        self.deinit_pwm()
        super().off()
    def deinit_pwm(self):
        machine.PWM(self.pin).deinit()
if __name__ == '__main__':
    relay = Led(name='relay', pin=machine.Pin(12, machine.Pin.OUT), on=1, off=0)
    power_led = PwmLed(name='power', pin=machine.Pin(13, machine.Pin.OUT), on=0, off=1)
    relay.on()
    utime.sleep(1)
    relay.off()
    for dim_level in range(power_led.dim_max_level):
        power_led.off()
        print(dim_level)
        power_led.set_dim_level(dim_level)
        power_led.on()
        utime.sleep(1)
        power_led.flash()
        utime.sleep(1)
    power_led.off()
The Problem is the
power_led.flash()
... it works only for the max dim level. the lower dim levels has some flickering...
Any idea? Any better implementation?
MostlyHarmless
Re: dim LEDs
Post by MostlyHarmless » Thu Dec 19, 2019 5:50 pm
The device has an ESP8266, right? On that chip PWM is emulated in software using an IRQ. That is why it has a very limited frequency and probably not the best stability either. Do you have an oscilloscope to verify?
nagylzs
Re: dim LEDs
Post by nagylzs » Thu Dec 19, 2019 6:11 pm
I'm working on a LEDC driver for MicroPython and ESP32 that will be able to do fading from hardware, in the background. It is in early stages, but it might be usable next year. For esp8266, there is no such solution.
jedie
Re: dim LEDs
Post by jedie » Thu Dec 19, 2019 6:59 pm
Yes, i need this on ESP8266 ... If PWM is emulated in software does it then load the CPU and make everything slower?
I think i have a bug in the "is_on" check that result in flickering...
jedie
Re: dim LEDs
Post by jedie » Thu Dec 19, 2019 8:59 pm
I have now tried different variations. But it seems to me that machine.PWM() is buggy, isn't it?
e.g.: There are situations where I can't get the LED off. It always lights up with 100%. Hard reset changes nothing. I have to turn off the power.
EDIT: Ah! It seems that pwm.deinit() will not really reset.
Work-a-round is:
pwm.freq(100)
pwm.duty(0)
pwm.deinit()
jedie
Re: dim LEDs
Post by jedie » Thu Dec 19, 2019 9:30 pm
This is now my working version:
import utime
class Led:
        self.name = name
        self.pin = pin
        self._on = on
        self._off = off
        self.is_on = None
        self.off()
    def on(self):
        self.is_on = True
    def off(self):
        self.is_on = False
    def toggle(self):
        if self.is_on:
            self.off()
            self.on()
    def flash(self, sleep=0.5, count=6):
        was_on = self.is_on
            self.toggle()
            utime.sleep(sleep)
        if was_on:
            self.on()
            self.off()
    @property
    def state(self):
    def __str__(self):
class PwmLed(Led):
        self.duty_values = (None, 700, 900, 1000)
        self.dim_max_level = len(self.duty_values)
        self.duty = None  # Full ON
        self.pwm = machine.PWM(self.pin, freq=100, duty=0)
        assert 0 <= dim_level <= self.dim_max_level, 'level %r is not between 0 and %i' % (
        was_on = self.is_on
        self.duty = self.duty_values[dim_level]
        if self.duty is None:
            self.off()
            self.deinit_pwm()
        if was_on:
            self.on()
    def on(self):
        if self.duty is not None:
            self.is_on = True
            self.pwm.duty(self.duty)
            super().on()
    def off(self):
        super().off()
            self.deinit_pwm()
        self.pwm.duty(0)
        self.pwm.freq(100)
        self.pwm.deinit()
    for level in range(power_led.dim_max_level):
        print('\nset level to: %i' % level)
        power_led.set_dim_level(level)
        power_led.flash()
    power_led.off()
