Build Secrets
Re: Build Secrets
Post by jimmo » Tue Dec 24, 2019 3:41 am
Definitely prefer the second (i.e. extend the port manifest, rather than duplicating it).
devnull
Re: Build Secrets - NRF Programming
Post by devnull » Tue Jan 07, 2020 9:05 am
NRF FLASHING
OK, here's some information that will save some time for others trying to program the NRF with Chinese STLINK and The Black Magic Probe:
I have tested with openocd, pyocd and gdb, all are latest versions.
The latest firmware of STLINK does not apear to allow mass erase, so this would fail, the others succeeded for me, however you may have to update the firmware on the STLINK if prompted during the flash process.
## SOURCE FILES
BTFW61="some_path/micropython/ports/nrf/drivers/bluetooth/s140_nrf52_6.1.1/s140_nrf52_6.1.1_softdevice.hex";
APPHEX="some_path/holyiot_18010-200106-1070984.hex";
## STLINK-V2 - fails during mass erase (stlink v2 not supports ??)
openocd -f interface/stlink.cfg -f target/nrf52.cfg -c init -c "reset init" -c halt -c "nrf mass_erase" -c "program $BTFW61" -c "program $APPHEX verify" -c reset -c exit
## STLINK-V2
TARGET="--target nrf52";
pyocd cmd -c "reset init" $TARGET;
pyocd cmd -c "halt" $TARGET
pyocd erase --mass-erase $TARGET;
pyocd flash $BTFW61 $TARGET --format hex;
pyocd flash $APPHEX $TARGET --format hex;
pyocd cmd -c "reset" $TARGET;
## BLACK MAGIC PROBE
gdb -ex "target extended-remote /dev/cu.usbmodem79AD7EA61" -ex "monitor tpwr enable" -ex "monitor swdp_scan" -ex "attach 1" -ex "load $BTFW61" -ex "load $APPHEX" -ex quit;
RWLTOK
Re: Build Secrets - Frozen Manifest
Post by RWLTOK » Mon Mar 02, 2020 1:22 am
Ok. What am I doing wrong?
I have these two lines in my frozen manifest file:
freeze('../../../../../Micropython-Library-Development/lib/uasyncio')
freeze('../../../../../Micropython-Library-Development/lib/','unittest.py')
Instead of getting a module named uasyncio, I got modules called '__init__, asyn, core, queues, and synchro'.
These are the python files in the directory '../../../../../Micropython-Library-Development/lib/uasyncio'
The module unittest appears fine. How do you include a module that is a subdirectory of files with __init__.py?
>>> help('modules')
__init__          micropython       ucollections      urandom
__main__          network           uctypes           ure
_onewire          xxxx              uerrno            uselect
asyn              pyb               uhashlib          usocket
builtins          queues            uheapq            ustruct
cmath             stm               uio               utime
core              synchro           ujson             utimeq
framebuf          sys               umachine          uzlib
gc                uarray            unittest
math              ubinascii         uos
Plus any modules on the filesystem
Rich
devnull wrote:
Tue Dec 24, 2019 3:02 am
If you have a custom manifest file, In order to include the files in the port/modules folder (which are the default frozen files) you need to include the modules folder in your manifest file:
freeze('$(PORT_DIR)/modules')
OR
include('$(PORT_DIR)/boards/manifest.py')
freeze("modules")
If you don't then things might be broken, such as on the esp32 you will be unable to access the file system
Re: Build Secrets
Post by jimmo » Mon Mar 02, 2020 1:44 am
This is a bit weird, but there's an example in ports/esp8266/manifest_release.py
# uasyncio
freeze("$(MPY_LIB_DIR)/uasyncio", "uasyncio/__init__.py")
freeze("$(MPY_LIB_DIR)/uasyncio.core", "uasyncio/core.py")
It makes sense when you realise that the second argument is also the effective destination path, but I also realise that's a bit non-intuitive.
RWLTOK
Re: Build Secrets
Post by RWLTOK » Mon Mar 02, 2020 2:00 am
Thanks jimmo,
It does make sense.
Rich
# uasyncio
