With old firmware, my NodeMCU device reset automatically if button (GPIO0) was hold for more then 8 sec. Therefore I counted 6 seconds (with sound feedback to user after each second), and after that switch AP mode on. Copy of code bellow.
With new firmware same NodeMCU resets after only 2 or 3 seconds. So I can not use this function any more.
Something changed in firmware between those two versions, regarding this issue?
Old firmware used: esp8266-20190125-v1.10
New firmware used: esp8266-20191220-v1.12
(I did erase flush while upgrading)
def pinBTN_cb(p):
a=machine.disable_irq()
if p.value() == 0:
t0 = time.ticks_ms()-1001
t1 = t0
b = 0
# loop waiting button release
while p.value() == 0:
t2 = time.ticks_ms()
# sound tick every sec
if (t2-t1)>=1000:
print('tick: ' + str(int((t2-t0-1000)/1000)) + ' sec')
sound(0)
t1=t2
# sound tick after 6 sec
if ((t2-t0)-1000>=6000 and b==0):
sound(1)
b=1
# after release, continue program, b = number of seconds while pressed
d=int((t2-t0-1000)/1000)
# short click (less then 1 sec)
if d==0:
# send some mqtt message
# more then 6 sec
if d>=6:
print('STARTING AP')
sound(1)
do_AP_onoff(True)
machine.enable_irq(a)
