@stijn, yes, I think opening an Issue is the way to go. Thanks for the suggestion.
You asked for an example of what I had in mind. This is for the MicroPython .mpy files page:
First paragraph. You should mention that boot.mpy and main.mpy are not recognised by the runtime interpreter. If you want a main.mpy a simple workaround is to rename it, say, app.mpy and have a one line main.py that imports it.
Second paragraph. There is no mention of where to get the cross compiler. The normal way is to set up a MP build environment on your computer. However, there is a simpler way if you are not interested in frozen bytecode, namely, use one of the pre-built distributions on PyPI.
As you can see, I only wish to highlight omissions or clarify matters, not specify the actual wording.
@jedie, thanks for your input. This information would be a very useful addition to the MicroPython Contributor Guidelines on Github.
