Running a multi line python script from memory
usjcarkm
Post by usjcarkm » Mon Jun 22, 2015 7:16 pm
Is there a way to run a multi line python script from memory (not from a File, since
my embedded op system doesn't support this and also don't need it) ?
Is there a form that takes a char* of the multi line python script itself
versus a file name ?
I don't have files, just the script in memory (hard coded in a const char*
for now, but could also be received from a socket at some point in the near future)
This seems like a straight forward need, but I haven't found any good examples.
Here is a simple example of the kind of script I need to run:
count = 0
while count < 5:
    print count
    count += 1
I won't be able to use this form:
int pyexec_file(const char *filename);
Here is what I would like to do, though it does not work
(note, that I have tried calling do_str() by passing in the entire string with carriage returns, as listed in many main.c files in the micropython project, but it doesn't work and get the following error:
  File "<stdin>"
SyntaxError: invalid syntax
These two scripts when executed individually works via the do_str() call:
print('hello world')
print('hello world!', list(x+1 for x in range(10)), end='eol\\n')
I tried instead calling the function pyexec_event_repl_process_char() as follows for each char in string
and it also fails to execute.
int stack_dummy;
stack_top = (char*)&stack_dummy;
#if MICROPY_ENABLE_GC
gc_init(heap, heap + sizeof(heap));
#endif
mp_init();
const char* src = "count = 0\n"
		  "while count < 5:\n"
    		  "  print count\n"
    		  "  count += 1\n";
char* pChar = src;
while(*pChar != '\0')
  pyexec_event_repl_process_char(*pChar);
  pChar++;
mp_deinit();
Damien
Site Admin
Re: Running a multi line python script from memory
Post by Damien » Mon Jun 22, 2015 8:04 pm
usjcarkm wrote: Is there a way to run a multi line python script from memory (not from a File, since
Yes, use the do_str() function but replace MP_PARSE_SINGLE_INPUT with MP_PARSE_FILE_INPUT. This will parse the input string as though it were a file, instead of a single line.
usjcarkm
Post by usjcarkm » Mon Jun 22, 2015 9:57 pm
Thanks. Worked great.
I also mistyped the the print line. Should enclose the param as shown below:
count = 0
while count < 5:
 print(count)
 count += 1
