stumped
uxhamby
stumped
Post by uxhamby » Mon Feb 03, 2020 8:26 pm
Dear sage denizens of the Micropython forums,
Likely I am missing something simple.
I have been playing around with a bit of code to exercise an old piece of hardware that I have here. Nothing too fancy, but I am getting an error that currently has me stumped.
My code 'test3.py' currently:
#!/usr/bin/env micropython
import mcp23017
import sys
import utime
i2c = I2C(scl=Pin(22), sda=Pin(21))
mcp = mcp23017.MCP23017(i2c, 0x20)
BlueLed = Pin(16,Pin.OUT)
BlueLed.value(1)
repl_button = machine.Pin(0, machine.Pin.IN, machine.Pin.PULL_UP)
x=0
# list interface
mcp[0].output(0)
mcp[1].output(0)
mcp[2].output(0)
mcp[3].output(0)
mcp[4].output(0)
mcp[5].output(0)
mcp[6].output(0)
mcp[7].output(0)
mcp[8].input(pull=1)
mcp[9].input(pull=1)
mcp[10].input(pull=1)
mcp[11].input(pull=1)
mcp[12].input(pull=1)
mcp[13].input(pull=1)
mcp[14].input(pull=1)
mcp[15].input(pull=1)
    # If button 0 is pressed, drop to REPL
    if repl_button.value() == 0:
        mcp.porta.gpio = 0
        #Line 44 follows next
        BlueLed.value(0)
        print("Dropping to REPL")
        sys.exit()
    # Turn LED on and then off
    mcp.porta.gpio = x
    #print(mcp.porta.gpio)
    utime.sleep_ms(500)
    BlueLed = not BlueLed
    x +=1
The error I get:
MicroPython v1.12-87-g96716b46e on 2020-01-26; ESP32 module with ESP32
>>> import test3
File "test3.py", line 44, in <module>
AttributeError: 'bool' object has no attribute 'value'
Looks to me like a variable scope issue yet, I am unaware of loops posing a such a dilemma, and I can't find anything documenting variable scope specs for within while loops.
Yes, I know my code is all a bit rough around the edges, but it was never intended to be ready for prime time. This is really just an ongoing experiment and its really just this error I am seeking an assist with, thanks.
Your thoughts would be appreciated.
Cheers,
Brian H.
Re: stumped
Post by OutoftheBOTS_ » Mon Feb 03, 2020 9:21 pm
I think you have a namspace problem. You import machine but then use Pin
try this
import sys
import utime
BlueLed = machine.Pin(16,Pin.OUT)
Re: stumped
Post by jimmo » Mon Feb 03, 2020 9:38 pm
You should make the change suggested by OurOfTheBots, but the actual issue is this line
This has the effect of setting BlueLed initially to False.
You should write
BlueLed.value(not BlueLed.value())
uxhamby
Re: stumped
Post by uxhamby » Mon Feb 03, 2020 10:26 pm
Yes, this has made all the difference.
Thanks jimmo, one and all !!
Brian H.
