Different debugging behavior running codes
davidbogatec
Post by davidbogatec » Wed Feb 12, 2020 7:13 am
I have to esp32 boards:
- board 1 with espressif esp32-WROOM 32 chip
- board 2 with espressif ESP32-WROVER B chip
On both the same firmware is uploaded.
On both the same code is running with a type error on line 4 (micropython1 instead of micropython).
import micropython
micropython1.mem_info()
Board 1 REPL output
Ready to download this file,please wait!
download ok
exec(open('mem.py').read(),globals())
File "<string>", line 4, in <module>
NameError: name 'micropython1' isn't defined
Board 2 REPL output
download ok
T
Board 1 is making a debug, while board 2 is giving only an error in a form of T character.
How i can solve the problem? I need to have debugging on all esp boards.
david
Re: Different debugging behavior running codes
Post by jimmo » Sat Feb 15, 2020 5:08 am
Where is "micropython1" coming from?
Can you try using a serial console (miniterm, rshell, putty, picocom, screen) directly and using pyboard.py or rshell to copy the files to the device?
aleskeyfedorovich
Post by aleskeyfedorovich » Tue Jun 30, 2020 12:33 pm
I think that David is asking why some boards do print the error line and other don't. He made the error with micropython1 on purpose to show his problem.
I have the same problem.
Since this problem is present/absent with same version of micropython and just changing the board I suppose is an hardware problem but I don't have any solution and I'd love to hear one.
aleskeyfedorovich
Post by aleskeyfedorovich » Tue Jun 30, 2020 1:21 pm
I just found that using putty instead of upycraft let you see errors
