hello,
i will have several ESP32 on my wifi router and everyone is called ' expressif' ,
is it possible to change the name?
thank
[resolved]change name esp32 expressif
Re: change name esp32 expressif
Hello
Yes you can change the hostname this is what I use.
import network, ntptime, utime, machine
sta_if.active(True)
# Next Line changes the hostname.
sta_if.config(dhcp_hostname="ComputerTest2")
sta_if.connect('*****', '*****')
print("Connecting ")
while not sta_if.isconnected():
print(".", end="")
utime.sleep(1)
ntptime.settime()
except:
pass
thank you very much
but no dhcp ,
it's ok , it's work
but no dhcp ,
it's ok , it's work
