Sending and decoding data over UART
psereni
Post by psereni » Thu Feb 27, 2020 12:21 pm
I'm pretty new here with micropython and I'm facing a problem that I can not solve.
Basically, I use the Pyboard to read a Pentiometer on Input X19 and I wanto to send the read value via UART to a Host (PC, or, later a Raspberry PI) where a Python script is polling the serial interface.
PyBoard Code is:
from pyb import Pin, ADC, UART, LED
led = LED(4)
adc = ADC(Pin("X19"))
uart = UART(1,9600)
uart.init(9600, bits=8,parity=None, stop=1)
    a=adc.read()
    uart.write(str(a))
    print(a)
    pyb.delay(250)
    led.toggle()
This code woks fine. When I use Putty to open a REPL on pyboard I see the correct values (from 0 to 4095, depending on the Potentiometer setting). E.g. the output is:
385
385
386
I use the following code to open the corresponding COM port on the PC:
#!/usr/bin/python3
import serial
sp=serial.Serial("COM8", 9600, timeout=1)
    data=sp.read()
#    print(data)
#    print(data.decode())
    print ((data.decode().strip()))
The point is, that I found no way of reading a correct string on the PC. I mean that I was not able to find a way of the reading the "right" numbers of bytes...
In the specific case the result will be:
3
8
5
3
8
5
3
8
6
The python routine on the PC should be able to understand that the measurement could vary from "0" to "4095". How??
Any help will be greatly appreciated.
doublevee
Re: Sending and decoding data over UART
Post by doublevee » Thu Feb 27, 2020 12:49 pm
A simple solution might be to transmit a newline character after your uart.write() on the PyBoard. This way, you can read the serial bytes and split them using this character.
I also think there is a command in PySerial that reads until a newline is received.
Post by jimmo » Thu Feb 27, 2020 1:06 pm
Yup, exactly what doublevee said -- you probably want to use the readline() method in pyserial rather than read(1), and ensure that you append a newline to the end of each uart.write() that you do on the pyboard.
The more complicated answer is that writing serial protocols is complicated and coming up with a reliable and robust way to frame your messages is important, and often you'll end up having to read a byte at a time and implement some sort of state machine to track where in the frame you are.
In this case it's pretty straightforward -- keep appending characters to a buffer until you see a newline. (But that's what pyserial.readline() does).
psereni
Post by psereni » Thu Feb 27, 2020 1:32 pm
Thank you so much, it works perfectly.
I added uart.write("\n") after uar.write(str(data)) on the pyboard code and used data=sp.readline() on the PC.
Thanks again
