Strange packet received
niclas@hedhman.org
Post by niclas@hedhman.org » Fri Mar 06, 2020 12:55 am
I am using MicroPython on PyCom module LoPy4, and in-house compile;
Pycom MicroPython 1.18.2.r7 [df9f237-dirty] on 2019-06-13; LoPy4 with ESP32
I am not a Python programmer, but very experienced in many other languages, so even if my Python questions look stupid, please don't treat me like an idiot.
I have encountered a strange situation that happens "sometimes" and the frequency of it occurring seems to be LoPy unit dependent, i.e. some of those I have do it much more commonly and others not at all.
        received_packet = self.lora_sock.recv(512)
        if isinstance( received_packet, bytes ) :
            packet_length = len(received_packet)
And I get the error;
TypeError: object of type 'function' has no len()
So, can a 'bytes' instance also be a function, and lacking the len() function? Could "received_packet" possible "change" from "bytes" to "function" between the isinstance() call and the len() call?
And yes, I am not dreaming this. The program is quite short, output goes to serial port and that is captured to log file on a Raspberry Pi "as-is", and the whole stacktrace in it and the line number matches the source code.
Any help is greatly appreciated.
// Niclas
Re: Strange packet received
Post by dhylands » Fri Mar 06, 2020 4:15 am
Without seeing your code, I'll guess that your variable does contain a function. If you did this:
data = foo
but you really meant to do this:
data = foo()
then data will contain the function foo and not the results of calling the function foo.
niclas@hedhman.org
Post by niclas@hedhman.org » Sat Mar 07, 2020 8:59 am
Nah. The code I posted is literally the 3 lines (+a blank in between) from the code. The LoRa module (from pycom-micropython-sigfox repository) is written in C, and interfaces with Python in ways I have no idea.
My question could perhaps be phrased; How is it possible that "bytes" doesn't have "len()" function sometimes?
The whole function in question looks like below. And I am clueless how it can pass the "if isinstance" and then fail on "len()"
    def loraCycle(self):
            if packet_length >= 8:
                pycom.rgbled(0x002000)
                rssi = self.lora.stats()[1].to_bytes(2, "little")
                snr = int(self.lora.stats()[2]).to_bytes(2, "little")
                print('SensorData:' + ",".join(map(str, received_packet + rssi + snr)))
                pycom.rgbled(0x000000)
                if packet_length  > 0 :
                    print('Unexpected:' + ",".join(map(str, received_packet + rssi + snr)))
                    self.pingcounter = self.pingcounter + 1
                if self.pingcounter > 1000 :
                    print('ping')
                    self.pingcounter = 0
            print( "Unpexpected return value:" )
            print( type(received_packet) )
            print( received_packet )
Post by pythoncoder » Sat Mar 07, 2020 9:25 am
Indeed. Very odd. Here is how I'd set about debugging it
            except TypeError:
                print('Error', type(received_packet), received_packet)
            # Rest of code
Christian Walther
Post by Christian Walther » Sat Mar 07, 2020 10:07 am
>>> bytes = type(print)
>>> a = print
>>> isinstance(a, bytes)
True
>>> len(a)
I have no reason to suspect that that’s what’s happening here, but it’s a possibility.
niclas@hedhman.org
Post by niclas@hedhman.org » Thu Mar 26, 2020 6:07 am
@pythoncoder
I eventually got around to dig into this and took your advice...
            except TypeError:
            # Rest of code
Error <class 'bytes'> b''
Isn't that type expected??
