How to include a module
john7
Post by john7 » Mon Mar 16, 2020 11:19 am
in wifi.py I have
class WIFI:
    def do_connect():
    #import network
    station = network.WLAN(network.STA_IF)
    station.active(True)
    if not station.isconnected():
        station.connect('Niron', 'projects1234')
        while not station.isconnected():
            pass
    print('network config:', station.ifconfig())
in main.py
#import wifi
from wifi import WIFI
I get an error
ImportError: no module named 'wifi'
What should I do?
OlivierLenoir
Re: How to include a module
Post by OlivierLenoir » Mon Mar 16, 2020 4:08 pm
You forget to indent below def do_connect():.
Olivier Lenoir
john7
Post by john7 » Mon Mar 16, 2020 4:41 pm
It's copy/paste problem. In the code I have all indents. Besides the compiler alerts in case of bad indentation.
I use the Thonny IDE in case if it's important.
tve
Post by tve » Mon Mar 16, 2020 7:35 pm
The error gets eaten, it's very annoying. Connect to the REPL and try to import wifi manually, then you will see the error that is preventing import.
OlivierLenoir
Post by OlivierLenoir » Mon Mar 16, 2020 7:38 pm
Can you try adding self in def do_connect(self):?
I've made the following test in repl.
MicroPython v1.12 on 2019-12-20; ESP32 module with ESP32
paste mode; Ctrl-C to cancel, Ctrl-D to finish
=== import network
=== class WIFI:
===     def do_connect(self):
===         station = network.WLAN(network.STA_IF)
===         station.active(True)
===         if not station.isconnected():
===             print('connecting to network...')
===             station.connect('Niron', 'projects1234')
===             while not station.isconnected():
===                 pass
===         print('network config:', station.ifconfig())
>>> c = WIFI()
>>> c.do_connect()
I (16280) wifi: wifi driver task: 3ffe2f38, prio:23, stack:3584, core=0
I (32778) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE
I (32788) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE
I (32818) wifi: wifi firmware version: aeed694
I (32818) wifi: config NVS flash: enabled
I (32818) wifi: config nano formating: disabled
I (32818) wifi: Init dynamic tx buffer num: 32
I (32828) wifi: Init data frame dynamic rx buffer num: 32
I (32828) wifi: Init management frame dynamic rx buffer num: 32
I (32838) wifi: Init management short buffer num: 32
I (32838) wifi: Init static rx buffer size: 1600
I (32848) wifi: Init static rx buffer num: 10
I (32848) wifi: Init dynamic rx buffer num: 32
I (32948) phy: phy_version: 4102, 2fa7a43, Jul 15 2019, 13:06:06, 0, 0
I (32948) wifi: mode : sta (24:6f:28:17:ee:3c)
I (32948) wifi: STA_START
I (35008) wifi: STA_DISCONNECTED, reason:201
no AP found
I (37058) wifi: STA_DISCONNECTED, reason:201
no AP found
Olivier Lenoir
OlivierLenoir
Post by OlivierLenoir » Mon Mar 16, 2020 7:44 pm
I'm connected when I put my personnel wifi network parameter.
I (32594) network: CONNECTED
I (35534) event: sta ip: 192.168.100.83, mask: 255.255.255.0, gw: 192.168.100.254
I (35534) network: GOT_IP
network config: ('192.168.100.83', '255.255.255.0', '192.168.100.254', '192.168.100.254')
Olivier Lenoir
OlivierLenoir
Post by OlivierLenoir » Mon Mar 16, 2020 8:03 pm
I should consider the following code to be able to provide SSID and password.
class WIFI(object):
    def __init__(self, ssid, passwd):
        self.ssid = ssid
        self.passwd = passwd
        self.station = network.WLAN(network.STA_IF)
        self.station.active(True)
        if not self.station.isconnected():
            self.station.connect(self.ssid, self.passwd)
            while not self.station.isconnected():
                pass
        print('network config:', self.station.ifconfig())
conn = WIFI('Niron', 'projects1234')
conn.do_connect()
Olivier Lenoir
john7
Post by john7 » Tue Mar 17, 2020 5:57 am
the code is working if I put it in main.py. The problem to import from another file.
john7
Post by john7 » Tue Mar 17, 2020 5:59 am
As I understand Thonny looks in installation directory when it sees an import directive. May be I should provide the full path to the file?
OlivierLenoir
Post by OlivierLenoir » Tue Mar 17, 2020 8:46 am
  1. Create file wifi.py on your computer with the here bellow code
  2. Connect to your board rshell -p /dev/ttyUSB0
  3. Use rshell to copy wifi.py on your board cp wifi.py /pyboard/
  4. From rshell start repl
  5. You can now import your module from wifi import WIFI
  6. ...
olivier@ole02-t510:~/Documents/MicroPython/Forum$rshell -p /dev/ttyUSB0
[i]Using buffer-size of 32
Connecting to /dev/ttyUSB0 (buffer-size 32)...
Trying to connect to REPL  connected
Testing if ubinascii.unhexlify exists ... Y
Retrieving root directories ... /boot.py/
Setting time ... Mar 17, 2020 09:33:27
Evaluating board_name ... pyboard
Retrieving time epoch ... Jan 01, 2000
Welcome to rshell. Use Control-D (or the exit command) to exit rshell.[/i]
/home/olivier/Documents/MicroPython/Forum> cp wifi.py /pyboard/
/home/olivier/Documents/MicroPython/Forum> repl
Entering REPL. Use Control-X to exit.
>>>conn.do_connect()
File wifi.py
class WIFI(object):
        self.ssid = ssid
                pass
Olivier Lenoir
