Proximity sensor using VL53L0x
Maser
Post by Maser » Wed Mar 18, 2020 4:53 pm
Hello
I am trying to use the VL53L0x and a Trinket M0 to sense the presens of a person.
I have got it to work meassureing distance with the given CircuitPhyton code:
import board
import busio
import adafruit_vl53l0x
i2c = busio.I2C(board.SCL, board.SDA)
vl53 = adafruit_vl53l0x.VL53L0X(i2c)
vl53.measurement_timing_budget = 20000
print('Avstand: {0} mm'.format(vl53.range))
time.sleep(1.0)
But rather than meassuring distance I would like it to give a signal on any of the io pins of the Trinket (to drive a relay or a transistor).
I have spent the day looking for such a code with limited sucsess.
Can anybody help :?:
Regards Jan S
Re: Proximity sensor using VL53L0x
Post by Roberthh » Wed Mar 18, 2020 5:02 pm
It looks like the wrong place to ask. Better ask at the adafruit forum: https://forums.adafruit.com/
Maser
Post by Maser » Thu Mar 19, 2020 7:01 am
Thanks :D
devnull
Post by devnull » Sat Mar 28, 2020 3:56 am
Did you do a search ??
search.php?keywords=VL53L0x
There's already quite a lot about this device in these forums :D
