print
badryan
print
Post by badryan » Fri May 02, 2014 1:36 pm
Would it be a lot of work to add a simple "print"? I appreciate it's of little use when not connected to a screen, but for development work in the REPL I'd find it quite useful.
Boris
Re: print
Post by dhylands » Fri May 02, 2014 3:08 pm
Hi Boris,
print is there, but with the Python 3.3 syntax (so it requires parenthesis).
Micro Python build 1f85d62-dirty on 2014-05-01; NetduinoPlus2 with STM32F405RG
>>> print('Hello there %s' % 'Boris')
Hello there Boris
badryan
Re: print
Post by badryan » Fri May 02, 2014 3:24 pm
<blushes>Oh.</blushes> Thank you very very much! I've never looked at the actual differences between Python 2 and 3!
Re: print
Post by dhylands » Fri May 02, 2014 3:34 pm
And str.format is also somewhat supported.
print('This is {} test'.format('a'))
One place to look for examples is in the test tree. This tree contains test code which is run against python 3.3 and against MicroPython to confirm that MicroPython produces the same results.
So with str.format, for example, this works:
>>> print('{:+8,d}'.format(1234))
  +1,234
but this doesn't (yet)
>>> print('{foo:}'.format(foo=123))
TypeError: function does not take keyword arguments
I think that everything that's supposed to come after the colon is supported.
pfalcon
Re: print
Post by pfalcon » Fri May 02, 2014 4:07 pm
I'm glad you're aware ;-). I wanted to post a ticket to capture that, but didn't want it to sound as not appreciating your great work on supporting other format specifiers. But yep, there's yet a way to go before we have "complete" support for .format() or str %.
Awesome MicroPython list
pfalcon
Re: print
Post by pfalcon » Fri May 02, 2014 4:10 pm
badryan wrote:<blushes>Oh.</blushes> Thank you very very much! I've never looked at the actual differences between Python 2 and 3!
I didn't know too much of differences between python 2 and 3 when I started with MicroPython, and now I'm pretty much Python3-ready. That's alone a great outcome from being acquainted with MicroPython, as Python3 is indeed the future, which despite some its controversies, becoming as present as we speak (for example, many Linux distros switch to python3 as default one).
Re: print
Post by dhylands » Fri May 02, 2014 4:16 pm
Hey Paul,
File the ticket :) I've been developing for so long now that I have a pretty thick hide. Not to mention that at work, everything has to be reviewed by somebody else before it lands (gets checked in). It took me 9 review cycles to get my first bug landed :o
I'm also not one to take offense when bugs are found in my code. A bug is a bug and they should all be eradicated - it doesn't matter how they got there :D
asaf
Re: print on pycharm
Post by asaf » Fri Mar 01, 2019 3:32 pm
How can i see the print on pycharm on the terminal log?
Thabks
Screen Shot 2019-03-01 at 17.30.24.png (152.36 KiB) Viewed 3864 times
fstengel
Re: print
Post by fstengel » Fri Mar 01, 2019 4:34 pm
You seem to have an encoding problem: your program does not even parse. See this thread on stackoverflow.
_meet_seth
Re: print
Post by _meet_seth » Sun Jun 14, 2020 2:05 pm
Hello
I uploaded my code to esp8266 via pycharm. Just a simple statement print("Hello World"). When I execute this with REPL it works fine but when I flash it with main.py the pycharm window shows something like Soft Reboot and nothing gets printed.
Please Help
Thanks in advance
