urequest library with cookie support and some redirect enhancements
mardi2020
Post by mardi2020 » Mon Mar 23, 2020 8:47 pm
i extended the uurequest.py from pfalcon to support cookies, some improvement for redirects and a method to extract parts of larger response bodies, which don't fit in the heap of a ESP32.
https://github.com/mardigras2020/urequests
There are a lot of changes at once, which usually violate contribution guidelines, therefore i can't just open an PR.
So if somebody is interested - feel free to use.
mardi2020
Re: urequest library with cookie support and some redirect enhancements
Post by jimmo » Tue Mar 24, 2020 12:48 am
I'm keen to try a bit of a fresh approach to micropython-lib, so would be happy to help you try and get any improvements merged. urequests is a good example of the sort of module I'd like to see be more useful and understandable and these sound like good changes. See https://github.com/micropython/micropython-lib/pull/376 for some more context.
The "small, single-feature PR" convention does certainly help a lot with review. But if you're interested in trying to get it merged why not try and split it up into a few smaller commits? ("git add -p" is your friend here).
Otherwise hopefully someone else might be interested in doing this. Or I might get to it eventually.....
mardi2020
Post by mardi2020 » Tue Mar 24, 2020 7:01 am
I will give it a try in the next days.
mardi2020
mardi2020
Post by mardi2020 » Tue Mar 24, 2020 12:34 pm
i added a first part as PR where i'm sure it works standalone.
mardi2020
