UDP problems
chromecat
UDP problems
Post by chromecat » Tue Apr 07, 2020 12:05 pm
Hello, i try to figure out how to send UDP messages from a D1 mini with Wifi.
From normal Python in the same Network -> no problem
My code:
import usocket as socket
wlan.active(True)
wlan.connect('Test', 'test')
udp = socket.socket(socket.AF_INET, socket.SOCK_DGRAM)
addr = ("192.168.101.4", 11152)
data = "hello"
    udp.sendto(data, addr)
The sendto command results in a '5' so i guess it was send.
The d1 connects to the wifi (ifconfig() giving an IP adress)
When sending UDP with my Ipad to ("192.168.101.4", 11152) the message can be received.
Any thoughts? do i have any mistake in understanding?
