Micropython dictionary to C struct
Posted: Thu Apr 09, 2020 7:59 pm
by curiouswombat
I'm working on a project that requires developing rudimentary Protobuf support for Micropython. I've made an extmod module with a function that accepts a dictionary containing Protobuf message data. Since I'm using an embedded C Protobuf library (nanopb for anyone interested) to bring pb support to Micropython, I need to read the data from the dictionary into struct fields of the message. How can I go about this?
I suspect the answer lies in using the functions from objdict.c, but beyond that I have no idea. Thanks
Re: Micropython dictionary to C struct
Posted: Tue Apr 14, 2020 4:30 am
by jimmo
hi,
Yes, exactly what you said about objdict.
Conceptually, the underlying structure is a "map", and "dict" is the Python-level API around it.
So you can either use the dict methods (see py/obj.h)
size_t mp_obj_dict_len(mp_obj_t self_in);
mp_obj_t mp_obj_dict_get(mp_obj_t self_in, mp_obj_t index);
mp_obj_t mp_obj_dict_store(mp_obj_t self_in, mp_obj_t key, mp_obj_t value);
mp_obj_t mp_obj_dict_delete(mp_obj_t self_in, mp_obj_t key);
It would also be worth looking at the implementation of modujson's dump method, which ultimately ends up calling dict_print (in objdict.c), which shows how to use dict_iter_next to iterate the items in the dictionary.
...or you can get the map directly (using mp_obj_dict_get_map) and then use the low-level map function (also in obj.h)
mp_map_elem_t *mp_map_lookup(mp_map_t *map, mp_obj_t index, mp_map_lookup_kind_t lookup_kind);
Posted: Mon Feb 08, 2021 10:27 pm
by RWLTOK
Any progress on this curiouswombat?
