I work with a nucleo F411 but i have a problem with UART on the "ARDUINO HEADER".
I use the UART6 on the NUCLEO HEADER but it's missing on the ARDUINO-HEADER.
Can I redirect the UART6 to the pin's of UART1 without rebuilding the firmware ?
In mpconfigboard.h there don't UART1
I have read the post of dhylands : viewtopic.php?t=5795#p33338.// UART config
#define MICROPY_HW_UART2_TX (pin_A2)
#define MICROPY_HW_UART2_RX (pin_A3)
#define MICROPY_HW_UART6_TX (pin_C6)
#define MICROPY_HW_UART6_RX (pin_C7)
// UART 2 connects to the STM32F103 (STLINK) on the Nucleo board
// and this is exposed as a USB Serial port.
#define MICROPY_HW_UART_REPL PYB_UART_2
#define MICROPY_HW_UART_REPL_BAUD 115200
If I have to rebuild the firmware and the file "pin.csv" contains all the pins, there is nothing else to modify in the file "mpconfigboard.h" before compiling ?
Thank you
