STMicroelectronics device having dfu mode i want to detect serial number using python. i'm not getting any soluton.
premannd8
Post by premannd8 » Tue May 05, 2020 10:12 pm
I'm having STMicroelectronics device which is in dfu mode i want to do upgrade but i'm unable to get python code to solve this problem. please help me.
Re: STMicroelectronics device having dfu mode i want to detect serial number using python. i'm not getting any soluton.
Post by jimmo » Thu May 07, 2020 3:47 am
Which ST device do you have? What sort of board? Are you able to get it into DFU mode with the BOOT0 pin?
Your best bet is to use dfu-util (see https://www.hanselman.com/blog/HowToFix ... ndows.aspx if you're using Windows), or the official ST tools.
Otherwise you can use pydfu.py which is part of hte MicroPython repo. https://github.com/micropython/micropyt ... s/pydfu.py
premannd8
Post by premannd8 » Sun May 17, 2020 2:29 pm
https://github.com/premananda8/usb/blob ... _libusb.py
please see above code using libusb in that code i want solution i'm not getting serial number when device is DFU, code is working perfectly when device is not in dfu mode. please help me.
Post by dhylands » Sun May 17, 2020 4:08 pm
When the device is in DFU mode,
dfu-util --list
shows the serial number at the end of each memory region:
$ dfu-util --list
dfu-util 0.9
Copyright 2005-2009 Weston Schmidt, Harald Welte and OpenMoko Inc.
Copyright 2010-2016 Tormod Volden and Stefan Schmidt
This program is Free Software and has ABSOLUTELY NO WARRANTY
Please report bugs to http://sourceforge.net/p/dfu-util/tickets/
Found DFU: [0483:df11] ver=2200, devnum=2, cfg=1, intf=0, path="20-2", alt=3, name="@Device Feature/0xFFFF0000/01*004 e", serial="336133663433"
Found DFU: [0483:df11] ver=2200, devnum=2, cfg=1, intf=0, path="20-2", alt=2, name="@OTP Memory /0x1FFF7800/01*512 e,01*016 e", serial="336133663433"
Found DFU: [0483:df11] ver=2200, devnum=2, cfg=1, intf=0, path="20-2", alt=1, name="@Option Bytes  /0x1FFFC000/01*016 e", serial="336133663433"
Found DFU: [0483:df11] ver=2200, devnum=2, cfg=1, intf=0, path="20-2", alt=0, name="@Internal Flash  /0x08000000/04*016Kg,01*064Kg,07*128Kg", serial="336133663433"
Post by dhylands » Sun May 17, 2020 4:25 pm
With the following change to micropython/tools/pydfu.py running pydfu.py --list will show the serial number:
diff --git a/tools/pydfu.py b/tools/pydfu.py
index 658ce59ae..7236f838c 100755
--- a/tools/pydfu.py
+++ b/tools/pydfu.py
@@ -462,9 +462,10 @@ def list_dfu_devices(*args, **kwargs):
         print("No DFU capable devices found")
         return
     for device in devices:
-        print("Bus {} Device {:03d}: ID {:04x}:{:04x}"
+        print("Bus {} Device {:03d}: ID {:04x}:{:04x} Serial {}"
               .format(device.bus, device.address,
-                      device.idVendor, device.idProduct))
+                      device.idVendor, device.idProduct,
+                      get_string(device, device.iSerialNumber)))
         layout = get_memory_layout(device)
         print("Memory Layout")
         for entry in layout:
Here's the output of pydfu.py --list with the above change:
$ ./pydfu.py --list
Bus 3 Device 005: ID 0483:df11 Serial 336133663433
Memory Layout
    0x8000000  4 pages of  16K bytes
    0x8010000  1 pages of  64K bytes
    0x8020000  7 pages of 128K bytes
premannd8
Post by premannd8 » Thu Jul 02, 2020 11:28 am
it always coming to No DFU capable devices found
Post by dhylands » Thu Jul 02, 2020 6:31 pm
If it's coming up with no DFU devices detected, then your device isn't in DFU mode (or you have a bad USB cable). You need to connect BOOT0 needs to be high, and BOOT1 needs to be low, then RESET. That should put your device in DFU mode.
What board are you using?
Post by jimmo » Fri Jul 03, 2020 5:55 am
Are you on Linux? does `dmesg` show anything when you connect the device?
Does `sudo dfu-util --list` help? If so you might need to check your udev rules.
