Lorawan TTGO board - 'no module named ttn'
matt42
Post by matt42 » Fri May 08, 2020 3:02 pm
Hi all,
I am trying to connect a TTGO board to the Lorawan network, using this code - https://github.com/lemariva/uPyLoRaWAN/tree/LoRaWAN
I keep getting this error when running main.py:
SX version: 18
  File "<stdin>", line 59, in <module>
  File "sx127x.py", line 207, in __init__
ImportError: no module named 'ttn'
Line 59 in main.py:
lora = SX127x(device_spi, pins=device_pins, ttn_config=ttn_config)
Line 207 in sx127x.py:
from ttn.ttn_au import TTN_FREQS
ttn_config.py and ttn_au.py are both there
I seem to be missing the ttn module but cannot find it for MP, the only reference I can find is for standard Python. Does anyone have any pointers?
Hardware:
https://www.banggood.com/LILYGO-TTGO-T- ... rehouse=CN
thanks in advance,
Matt
T-Wilko
Re: Lorawan TTGO board - 'no module named ttn'
Post by T-Wilko » Fri May 15, 2020 9:57 am
I don't know exactly how you've stored your on-board files, but shouldn't the code be this?
from ttn_au import TTN_FREQS
T-Wilko
Post by T-Wilko » Tue May 19, 2020 3:15 am
No worries! Just out of curiosity, did you manage to get the TTGO board's LoRa functionality working?
I've been looking at getting my TTGO T-Beam's LoRa module functional sometime soon, and I also was eyeing off that repo that you first linked to.
lemariva
Post by lemariva » Wed May 20, 2020 7:45 am
The main.py expects that you upload the folder structure to the board too. If you use VSCode and the PyMakr plugin (https://lemariva.com/blog/2018/12/micro ... ode-as-ide), this is done by default. If you uploaded every file on the root / folder, you need to remove the ttn. prefix from the imports. Last Sunday, I upgraded the repository and added a configuration for the M5Stack with the LoRa868 Module. Now, it should be easier to configure new boards. :)
