Tuto HID mousse with nucleo411
P@T
Post by P@T » Wed May 13, 2020 11:53 am
I try the tutorial with a board nucleo411 but it is possible ?
I don't know how to access the boot file ...
I don't see : usb_mode
>>> MicroPython v1.12-371-gf534b9976 on 2020-04-15; NUCLEO-F411RE with STM32F411xE
>>> import pyb
>>> pyb.
__class__       __name__        main            stop
RTC             ADC             ADCAll          ExtInt
Flash           I2C             LED             Pin
SPI             Switch          Timer           UART
bootloader      country         delay           dht_readinto
disable_irq     elapsed_micros  elapsed_millis  enable_irq
fault_debug     freq            hard_reset      info
micros          millis          mount           repl_info
repl_uart       standby         sync            udelay
unique_id       wfi
Well, someone could give me some advice ?
Thank you
Re: Tuto HID mousse with nucleo411
Post by dhylands » Wed May 13, 2020 1:24 pm
The USB connector on the nucleo411 is connected to the STINK MCU on the nucleo board. There is no USB connector connected to the STM32F411, so the USB functionality is disabled by default. This is why there is no usb_mode function.
In order to get USB functionality to work, you'd need to wire up a USB connector and rebuild the firmware with USB enabled.
shaoziyang
Post by shaoziyang » Wed May 13, 2020 1:44 pm
USB is disable in Nucleo64 board default, because it doesn't have a USB socket for STM32. You may enable usb by add line below in mpconfigboard.h.
#define MICROPY_HW_ENABLE_USB (1)
P@T
Post by P@T » Wed May 13, 2020 3:00 pm
thank you for your response.
In DFU mode there is a USB port on stm32f411 ? PA_11 and PA_12
I try to rebuild a firmware (it's the first time, I hope it's not hard)
P@T
Post by P@T » Wed May 13, 2020 3:04 pm
I'm sorry shaoziyang, i didn't see your answer.
I'm going to add this line and follow the instructions.
(If i have any problems, I can ask for your help ?)
Thank you
shaoziyang
Post by shaoziyang » Thu May 14, 2020 1:17 am
After enable usb in mpconfigboard.h, you need build source and update firmware. Then connect PA11/PA12 to a usb adapter board.
shaoziyang
Post by shaoziyang » Thu May 14, 2020 1:32 am
I have also make a nucleo shield board before.
viewtopic.php?f=12&t=2343&p=13430#p13430
P@T
Post by P@T » Thu May 14, 2020 12:18 pm
I have to add the line 7
#define MICROPY_HW_BOARD_NAME       "NUCLEO-F411RE"
#define MICROPY_HW_MCU_NAME         "STM32F411xE"
#define MICROPY_HW_HAS_SWITCH       (1)
#define MICROPY_HW_HAS_FLASH        (1)
#define MICROPY_HW_ENABLE_RTC       (1)
and I have a problem :
pat@pat-3000-N100:~/micropython/ports/stm32$ make BOARD=NUCLEO_F411RE
GEN build-NUCLEO_F411RE/genhdr/moduledefs.h
GEN build-NUCLEO_F411RE/genhdr/qstr.i.last
usb.c:56:2: error: #error Unable to determine proper MICROPY_HW_USB_MAIN_DEV to use
../../py/mkrules.mk:88: recipe for target 'build-NUCLEO_F411RE/genhdr/qstr.i.last' failed
make: *** [build-NUCLEO_F411RE/genhdr/qstr.i.last] Error 1
make: *** Suppression du fichier « build-NUCLEO_F411RE/genhdr/qstr.i.last »
an idea please ? a comment in usb.c ?
Thank you
shaoziyang
Post by shaoziyang » Thu May 14, 2020 2:21 pm
Macro MICROPY_HW_USB_FS also need to be set to enable USB.
// USB config
#define MICROPY_HW_USB_FS (1)
shaoziyang
Post by shaoziyang » Thu May 14, 2020 2:38 pm
// USB config
