does mpy take precedence over py?
smhodge
Post by smhodge » Sun May 17, 2020 6:10 pm
If you have both a x.py and x.mpy file on /flash or /sd, does the x.mpy file take precedence and get loaded, and the x.py file ignored?
aivarannamaa
Re: does mpy take precedence over py?
Post by aivarannamaa » Sun May 17, 2020 6:45 pm
It seems to be vice versa:
https://docs.micropython.org/en/latest/ ... files.html
When searching a particular directory foo.py is looked for first and if that is not found then foo.mpy is looked for, then the search continues in the next directory if neither is found. As such, foo.py will take precedence over foo.mpy.
