machine.Pin.pull_down ?
bellad
Post by bellad » Wed May 20, 2020 8:13 am
i have pin out from esp32 ( 1=activ ) , go to stm32 in pin
on stm32 , the pin in , i put machine.Pin.pull_down ? or other
esp32 ( pin out ) -> stm32 (pin in )
thank
SpotlightKid
Re: machine.Pin.pull_down ?
Post by SpotlightKid » Wed May 20, 2020 1:57 pm
Sorry, I don't understand a word of what you have written. Could you try to rephrase it?
bellad
Post by bellad » Mon May 25, 2020 2:09 pm
sorry for the delay
on my esp32 :
rel= machine.Pin(16, machine.Pin.OUT)
if a == 0:
rel.value=1
rel.value=0
with a physical wire esp32 to stm32 on PE8
if PE8 == 1 :
print('ok')
print('no good')
for PE8 declare machine.Pin.pull_down or machine.Pin.pull_up ?
Post by dhylands » Mon May 25, 2020 4:03 pm
Pull up and pull down are only applicable to input pins. Output pins are driven high or driven low, so pullups don't apply. I think you might be able to use pull up on an open drain output, but that's the only case I can think of tht makes sense.
According to the documentation: http://docs.micropython.org/en/latest/l ... achine.Pin
something like this:
p = machine.Pin('PE8', mode=machine.Pin.IN, pull=machine.Pin.PULL_UP)
bellad
Post by bellad » Thu May 28, 2020 2:26 pm
thank you ,
i hope " p = machine.Pin('PE8', mode=machine.Pin.IN, pull=machine.Pin.PULL_DOWN)
because i input +3.3v and 0v when nothing
chrismas9
Post by chrismas9 » Fri May 29, 2020 12:40 am
When you drive an input from a push pull source you don't need a pull-up or pulldown, just a normal high impedance input. You only need a pull resistor if the driving source can become high impedance, eg open drain or tristate.
If the ESP32 output is push pull, always either 0V or 3.3V, then the STM32 input does not need a pull-up or pulldown resistor.
The exception would be if the ESP32 went into a sleep mode where its outputs are disabled. I don't know if that happens.
