How to handle real time communication between PC and pyboard?
muziy
Post by muziy » Wed May 20, 2020 3:07 pm
Hello all,
This is a question from a newbie so please bear with me if I did anything stupid. I am trying to collect sensor data from my pyboard. process it with PC and send controlling command to the pyboard. The two-way communication needs to be done real time.
Two simple things I tried to do was (1). write from PC to pyboard and use it to control LED brightness and (2) collect the voltage from a pyboard pin and write the voltage value. I had no difficulty with (1). For (2), pyboard could not write to the PC and writting to the SD card requires reset.
I also referred to this post: viewtopic.php?t=1130
With pyboard.py tool I could only have the values printed on REPL, but not written to a txt file in real time.
Here is another code I tried for (2):
p1=pyb.ADC('X1')
	vol=p1.read()/4095*3.3
	f=open('log/data.txt','w')
	f.write(vol)
	f.close()
	delay(500)
The file won't be written until next pyboard reset (is it because the PC has the priority to write to the SD card?). Changing the 'log/data.txt' to a txt on the PC will give "no such file or directory" error.
I wondered if there is any way to collect values from pyboard and make it accessible for PC without reset. Any help is much appreciated.
ldbm
Re: How to handle real time communication between PC and pyboard?
Post by ldbm » Thu May 21, 2020 9:48 pm
Have you considered setting up a uart on the pyb, and communicating via a uart/USB (virtual COM) cable to the PC ?
Post by pythoncoder » Fri May 22, 2020 5:44 am
File sharing on an SD card won't work. This is because the PC expects the shared drive to be a dumb device like a pen drive. Trying to do this is likely to lead to a corrupt filesystem on the SD card.
A UART is a good solution if you're using a Pyboard 1.x. A Pyboard D has the added option of WiFi.
