rtc on STM32F407VET6 Black Board ??
bellad
Post by bellad » Thu May 28, 2020 2:23 pm
hello,
i try of setup init RTC with :
rtc=machine.RTC()
rtc.init((2014, 5, 1, 4, 13, 0, 0, 0))
TypeError: function takes 1 positional arguments but 2 were given
what is the right way to do it?
thank you
Re: rtc on STM32F407VET6 Black Board ??
Post by dhylands » Thu May 28, 2020 5:00 pm
Unfortunately, it really depends on the board you're using.
Here's rshell's code which runs on most boards. You can pick the one you're using and just use that:
https://github.com/dhylands/rshell/blob ... #L951-L985
jcw
Post by jcw » Fri May 29, 2020 3:23 pm
Yes, it looks like you need datetime iso init, here's a very similar board:
$ picocom -q -b115200 /dev/cu.usbmodem3167336E34362
MicroPython v1.12-464-gcae77daf0-dirty on 2020-05-24; VCC-GND STM32F407ZG with STM32F407ZG
>>> import machine
>>> rtc=machine.RTC()
>>> rtc.datetime()
(2015, 1, 1, 4, 0, 0, 0, 255)
>>> rtc.datetime((2014, 5, 1, 4, 13, 0, 0, 0))
>>> rtc.datetime()
(2014, 5, 1, 4, 13, 0, 3, 255)
Note that many API details can be inferred interactively:
>>> dir(rtc)
['__class__', 'calibration', 'datetime', 'info', 'init', 'wakeup']
>>> rtc.datetime(1)
TypeError: object 'int' isn't a tuple or list
>>> rtc.datetime((1,2))
ValueError: requested length 8 but object has length 2
bellad
Post by bellad » Tue Jun 02, 2020 1:35 pm
ok , thank you
but not enough memory to my prog ,
how to go back , remove micropython ?
bellad
Post by bellad » Thu Jun 04, 2020 9:45 am
grrrr...
>>> rtc.datetime((2020,6,4,11,43,0,0,0))
year, month , day ,hour,minute
>>> rtc.datetime()
(2021, 6, 4, 3, 3, 0, 1, 40)
oups , year , month , day , weekday , hour , minute ,
(2020,6,4,4,11,0,0,0,0)
good
bellad
Post by bellad » Thu Jun 04, 2020 12:21 pm
now the rtc init is good , i have put battery , but the rtc does not run on battery
exp:
with power : rtc.datetime()
(2020, 6, 4, 4, 14, 1, 32, 184)
no power on battery during 10mn
with power ( after 10mn )
rtc.datetime()
no change !!
