Generating autodocs for upython
ltmerlin
Post by ltmerlin » Sat Jun 06, 2020 7:37 pm
Is there a way to generate auto docs from upython code like we normally do with python?
Using Sphinx auto docs or mkdocstrings is not working as standard python is used to import the modules to be documented.
This leads to some issues if some modules are not importable (such as "import machine")...
Any advice/workaround or tips would be very much appreciated!
russ_h
Re: Generating autodocs for upython
Post by russ_h » Mon Jun 08, 2020 9:32 pm
I used the Sphinx sphinx.ext.autodoc extension to document my last MicroPython project. In my conf.py file I added the projects lib directory using sys.path.insert and autodoc_mock_imports for the rest of the modules.
sys.path.insert(0, os.path.abspath('../../lib'))  # add my lib modules
autodoc_mock_imports = [
    'machine',
    'board',
    'st7789',
    'network',
    'servo',
    'esp',
    'uos',
    'btree',
Russ
ltmerlin
Post by ltmerlin » Tue Jun 09, 2020 1:31 pm
Thanks for your answer. That works great with Sphinx!
It would also be nice to be able to do this using MkDocs. I did not found a way yet. Keep you posted.
pawamoy
Post by pawamoy » Sun Jul 26, 2020 10:01 pm
You can change sys.path and mock packages in mkdocstrings as well:
plugins:
  - mkdocstrings:
      handlers:
        python:
          setup_commands:
            - import sys
            - from unittest.mock import MagicMock as mock
            - sys.path.insert(0, os.path.abspath('../../lib'))
            - sys.modules['machine'] = mock()
            - sys.modules['board'] = mock()
            # etc
ltmerlin
Post by ltmerlin » Mon Jul 27, 2020 8:37 am
Hi pawamoy, thanks for the hint!
ltmerlin
Post by ltmerlin » Mon Jul 27, 2020 12:37 pm
I got the following error:
mkdocstrings.handlers.CollectionError: module 'lib' has no attribute 'helpers'
I added my lib dir which contains a helpers.py file which I want to document, but it does not seem to find it.
docs/helpers.md
## Documentation for Helper
::: lib.helpers
mkdocs.yml
- mkdocstrings:
      handlers:
        python:
          setup_commands:
            - import sys
            - sys.path.append("lib")
any idea why it does not find this module?
pawamoy
Post by pawamoy » Fri Aug 07, 2020 9:58 am
If you add the
lib
directory to
sys.path
, then you can write
::: helpers
directly.
