How to Execute Pythin Scripts
andyf9798
Post by andyf9798 » Sat Jun 13, 2020 2:55 pm
Hi Guys
I am new to Micropython and trying to get to grips with it.
I started with executing commands in Tera Terminal and I all looks to be fine.
example I type 2+2 and it is echo back 4
But then if I create a test.py that contains 2+4 and then import test I get errors
I would like to create tests code then execute it, but I cannot figure out how.
Re: How to Execute Pythin Scripts
Post by Roberthh » Sat Jun 13, 2020 3:02 pm
Please post the script and the errors.
andyf9798
Post by andyf9798 » Sat Jun 13, 2020 4:15 pm
this file called test.py
Then I try import test.py
result is
>>> import test
Traceback (most recent call last): File "<stdin>", line 1, in <module> ImportError: no module named 'test'
>>> import test.py
I cannot figure how to execute a script.
Post by Roberthh » Sat Jun 13, 2020 4:31 pm
Did you put that script onto your device?
Depending on your device type, you have several options. Which device are you using?
andyf9798
Post by andyf9798 » Sat Jun 13, 2020 4:35 pm
it is an STM32F407G-DISC1 development board, I have Micropythin running on it.
I copy the test.py to the same folder as boot.py and main.py called a PYBflash
The I connect to the board with Tera Term and I can execute the lines of the file but not execute it as a file.
Post by Roberthh » Sat Jun 13, 2020 6:19 pm
Did you disconnect the flash drive properly to ensure, that the file is actually written to your board?
SpotlightKid
Post by SpotlightKid » Sat Jun 13, 2020 8:03 pm
Also, when you manage to import your script properly, please not that all code of module thats on a global level is executed when importing it. It is therefor better to put it into a function, which you call after importing, Secondly, when executing a script (as opposed to the interactive prompt), you need to ouput the results of expressions with print, otherwise they will not show up.
def main():
    print(2+2)
>>> from test import main
>>> main()
4
andyf9798
Post by andyf9798 » Sun Jun 14, 2020 5:18 am
Ok Guys, Finally with your examples I managed to figure out where I was upside down.
I made this example testing.py
import ubinascii
def functionone():
	print('Hello from function 1!')
def functiontwo():
	print('Hello from function 2!')
def serialtest():
	id = machine.unique_id()
	serial_bytes = bytes([id[11], id[10] + id[2], id[9], id[8] + id[0], id[7], id[6]])
	serial = ubinascii.hexlify(serial_bytes).upper()
	print(serial)
So first of all, I save this to the board.
Then the magic came by resetting the board with Ctrl + D ( Soft Reboot)
MPY: sync filesystems
MPY: soft reboot
MicroPython v1.12 on 2019-12-20; F4DISC with STM32F407
and then
>>>import testing
no errors ( Finally )
Now the thing I did not know is you must call the functions preceded with testing.
so:
testing.functionone() results in Hello from function 1!
testing.functiontwo() results in Hello from function 2!
testing.serialtest() results in b'206D35824E48'
if I import the function directly like
import from testing function1
import from testing function2
import from testing serialtest
then I can call those functions without preceding them with testing.
This is something likely explained somewhere on a forum.
Two things I learnt today is that it seams to be mandatory to do soft-reboots each time some code is tested and the method of importing functions matters.
