Hallo
I have a problem with udp sockets
if i use self.__sock.sendto(self.__buffer, server_addressS) i get a a Error
File "<string>", line 27, in <module>
File "/lib/uPySip/sipMachine.py", line 185, in loop
File "/lib/uPySip/sipMachine.py", line 550, in __send
OSError: [Errno 12] ENOMEM
if i use gc.collect() after self.__sock.sendto(self.__buffer, server_addressS) then it works. But i can not runn each time the collect then the packages mus be send each 0.02s
the code is on Github https://github.com/RetepRelleum/uPyVoip ... Machine.py
regards Peter
Memory Error with sendto
Re: Memory Error with sendto
Wow I have solved my Problem
and
machine.freq(240000000)
if i%20==0: #Bad solution
gc.collect()
