Where is correct doc source?
hlovatt
Post by hlovatt » Wed Jul 01, 2020 12:41 am
Where is the correct location for the MicroPython docs source files, I can find two:
  1. https://docs.micropython.org/en/latest/ ... s/library/
  2. https://raw.githubusercontent.com/micro ... s/library/
Which is the correct source?
gatorchu
Re: Where is correct doc source?
Post by gatorchu » Wed Jul 01, 2020 1:27 am
Seems like the first one is the official one.
Post by dhylands » Wed Jul 01, 2020 6:17 pm
I think its the second one, which is really just a frontend for: https://github.com/micropython/micropyt ... cs/library
The first one, should be a "rendering" of whatever is found in the github repository.
hlovatt
Post by hlovatt » Wed Jul 01, 2020 8:27 pm
Thanks, both sources have both a rendering and raw versions.
Post by pythoncoder » Thu Jul 02, 2020 5:06 am
@hlovatt Your links throw 403 and 400 here. When making doc changes I've forked the source tree and proceeded as I described here. Doc changes and code changes are handled identically.
Post by jimmo » Thu Jul 02, 2020 6:42 am
The links don't work for me, but the background here:
Periodically the markdown (well, restructured text) is compiled with Sphinx to generate the HTML that is served by docs.micropython.org. The first URL is a snapshot of the markdown that was used to generate the site. (i.e. you're linking to the "latest" one, but equivalently there's the previous versions too.. e.g. 1.12, etc).
The second URL is a snapshot of the current master branch on github of those same markdown files. It turns out that GitHub knows how to render markdown, so it does its best (but really this site should be rendered by Sphinx).
hlovatt
Post by hlovatt » Thu Jul 02, 2020 11:36 pm
Thanks, that clarifies.
