KeyError that I don't Understand
DKuchen
Post by DKuchen » Sat Jul 04, 2020 12:09 am
I have a simple piece of code that is throwing me for a loop,
CONTROLLER_CONFIG = {
'ID': 1986,
'CE': 1,
'NI': 'Controller',
'AP': 4
def configure_node(**kwargs):
for cmd, value in kwargs.items():
print(cmd, ' ', value)
>>configure_node(**CONTROLLER_CONFIG)
When I run this i get a "KeyError: N". I can run this on my computer fine, but when I try to run in it through the micropython terminal from my xbee dev board it throws the error. I can also just run the For loop in the terminal with the same dictionary no problem.
Re: KeyError that I don't Understand
Post by jimmo » Sat Jul 04, 2020 6:37 am
On current github version of MicroPython this works fine.
MicroPython v1.12-618-gfeed2a046 on 2020-07-03; linux version
Use Ctrl-D to exit, Ctrl-E for paste mode
... 'ID': 1986,
... 'CE': 1,
... 'NI': 'Controller',
... 'AP': 4
...     for cmd, value in kwargs.items():
...         print(cmd, ' ', value)
ID   1986
AP   4
NI   Controller
CE   1
It also works on the (very old!) version of MicroPython running on the online simulator at http://micropython.org/unicorn/ so I'm don't think that this is a bug that's been fixed since Digi's version was forked?
I don't know much about MicroPython-on-xbee. As far as I know Digi haven't ever released source code for it? I wonder if maybe there's some feature they're disabling that's changing the behaviour of kwargs?
Maybe can you try running:
'ID': 1986,
'CE': 1,
'NI': 'Controller',
'AP': 4
  print(kwargs)
ESpy
Post by ESpy » Tue Jul 07, 2020 7:11 am
Not just on the simulator:
MicroPython v1.12 on 2019-12-20; ESP module with ESP8266
... 'ID': 1986,
... 'CE': 1,
... 'AP': 4
>>> print(CONTROLLER_CONFIG)
{'ID': 1986, 'AP': 4, 'NI': 'Controller', 'CE': 1}
... print(cmd, " ", value)
ID 1986
AP 4
NI Controller
CE 1
