mathieu wrote: ↑Sun Jul 26, 2020 5:37 pm
I have a pyboard-D powered by the 5V output of this step-down voltage regulator
What's powering the buck converter?
So you have two "grounds" -- the negative DC terminal of whatever's powering the buck converter, and also whatever's powering your laptop.
When you connect the pyboard to the laptop, you're now making this a common ground. The question is whether that's safe to do, as they either need to already be the exact same thing (i.e. both tied to earth), or at least one of them floating.
If the laptop is on battery, then there's no problem (i.e. it's floating). So if you want to be really sure, then that's a good way to go.
It's been a while since I saw it, but this video might help --
https://www.youtube.com/watch?v=xaELqAo4kkQ The point there is that your scope ground is not floating, so you need to be careful.
