Hi to all,
I have SIM800L module and D1 mini microcontroller with Micropython firmware...
Can those modules connect themselves and how? I would like to send SMS. I take SIM from my telecom provider...
Does anyone know good python script that works out of the box with those modules together? Some good links? I found couple of links but for ESP32 or Arduino or something other but I have those two modules and like to do this with micropython...
Thanx in advance,
Jadro
GSM SIM800L
Re: GSM SIM800L
You do have 2G support still in your country?
What is a D1?
What is a D1?
Re: GSM SIM800L
Yes I do have, 2G , 3G... and D1 mini is ESP8266 based microcontroller, Wemos D1 mini, it is on the picture I uploaded, It has Txd and Rxd pins
Re: GSM SIM800L
Will you have 2G for the life of your project? Sorry about the D1, I should look closer. I spent several weeks trying to get a ESP-01S to talk to a HotSpot using AT commands. Where are you going to send your data to?
Re: GSM SIM800L
Hi, I thing that 2G is neccessary just for internet (wifi) and my SIM800L will used as a SMS. Do you think that SMS is not in corellation with 2G?
Re: GSM SIM800L
https://en.wikipedia.org/wiki/2G says that 2G supports SMS.
ESP32 SIM800L Publish Data to Cloud wit ... Tutorials might be helpful. I bought one of these only to find out that GSM did not mean it would support 3G.
Good luck.
Good luck.
Re: GSM SIM800L
At last I found and buy this module TTGO T-Call ESP32 with SIM800L GPRS Module-Presolder Header and works great with MicroPython firmware and code. It calls, send SMS... As a charm
- ttgo.PNG (207.92 KiB) Viewed 4558 times
Re: GSM SIM800L
Hi Jadro,
I've got also this, how did you get it to work? Do you have any scripts for this? If I could ask you for your help, because I'm new to microcontrollers, and this is my first project. I've got the V 1.3 the similpier one.
Thanks,
Janos
