im trying to start two diffrent functions at the same time.
The first one is a webserver, the second one is a script to check the temperature of an DTH11.
Webserver:
def webserverThread():
print('Webserver_Started')
conn, addr = s.accept()
print('Got a connection from %s' % str(addr))
request = conn.recv(1024)
print('Content = %s' % str(request))
sensor_readings = read_sensor()
print(sensor_readings)
response = web_page()
conn.send('HTTP/1.1 200 OK\n')
conn.send('Content-Type: text/html\n')
conn.send('Connection: close\n\n')
conn.sendall(response)
conn.close()
def tempCheckerThread():
print('TempThread_Started')
if float(temp) > 30.0:
print('Try to send Mail')
send_mail_warn()
now i want to run both to the same time. I've tested _thread but when the Webserver function is running the thempcheck starts only after reloading the website..
Any Ideas for a newbie?
THX
Benny
Run two funktions at the same Time on ESP32
Re: Run two funktions at the same Time on ESP32
I recommend uasyncio rather than threading. It's more efficient. Threading has the potential for writing code with bugs which are extremely hard to find.
See this tutorial.
See this tutorial.
- rcolistete
Another hardware, K210 boards with Lobo firmware has the option :
Running two independent Micropython instances on two K210 cores is supported.
Rich set of functions for data exchange between instances is provided.
