i2c.readfrom timeout
pmulvey
Post by pmulvey » Fri Aug 14, 2020 3:30 pm
I am talking to my Arduino from ESP8266 via i2c. The Arduino code can sometimes take up to 36mS to complete the code that responds to the i2c.readfrom command at the ESP. After a few transactions the ESP throws an error:
  File "IO.py", line 110, in read
OSError: I2C bus error
Does anyone know if there is a timeout setting that I can use because I'm guessing that this is the problem.
Paul Mulvey
Re: i2c.readfrom timeout
Post by pythoncoder » Fri Aug 14, 2020 3:45 pm
Bus errors are often caused by electrical problems, especially missing pullup resistors or ones with too high a value. Also ensure that the wires are reasonably short and that you have a reliable common ground connection.
shaoziyang
Post by shaoziyang » Sat Aug 15, 2020 2:50 am
You may try reduce the frequency of the I2C bus.
