>>> from socket import *
>>> serverName= 'Localhost'
>>> serverPort=12345
>>> serverSocket=socket(AF_INET,SOCK_DGRAM)
>>> serverSocket.bind(("",serverPort))
>>> print("Calculating expressions..")
>>> file2.open("output,txt","w")
while 1:
exp,clientAddress=serverSocket.recvfrom(2048)
exp=exp.decode("utf-8")
print("Infix Expr Value")
print("----------------------")
file2.write("Infix Expr Value")
file2.write("---------------------")
for x in range(0,len(exp)):
if exp[x] >= "0" and exp[x]<="9":
list.append(exp[x])
elif exp[x]=="+"or exp[x]=="-" or exp[x]=="/" or exp[x]=="*":
op=exp[x]
list.append(op)
temp=list.pop()
if temp=="+":
num2=int(list.pop())
num1=int(list.pop())
ans=num1+num2
elif temp=="-":
ans=num1-num2
elif temp=="*":
ans=num1*num2
elif temp=="/":
ans=int(num1/num2)
print(exp," = ",ans)
ans=str(ans)
serverSocket.sendto(bytes (ans,"utf-8"),clientAddress)
file2.write(ans)
file2.write("\n")
print("-----------------------")
file2.close()
#print("Send answer of: ",ans,"to client")
serverSocket.close()
