Switching between tasks
Ventran
Post by Ventran » Tue Oct 27, 2020 9:46 pm
I have a questions. It it possible in micropython create e.g three tasks (include forever loop each) and switching between them.
This is a graph what i need to do:
I trying this but not work properly:
async def task1():
	todo()
        await asyncio.sleep_ms(500)
async def task2():
	todo()
        utime.sleep_ms(2000)
        await asyncio.sleep_ms(5000)
async def task3():
	todo()
        utime.sleep_ms(1500)
        await asyncio.sleep_ms(10000)
loop.create_task(task1())
loop.create_task(task2())
loop.create_task(task3())
loop.run_forever()
Re: Switching between tasks
Post by jimmo » Wed Oct 28, 2020 12:47 am
Yes what you're doing looks right except for the "utime.sleep_ms" -- you cannot use a blocking sleep in asyncio code. But you don't need it, the "await asyncio.sleep_ms" should be all you need.
So your diagram says you have three tasks that do something every 5, 5, and 2 seconds respectively.
This program does what I'd expect (see output below). However the thing to remember is that if whatever the "todo()" task is is blocking, then it will prevent other tasks from running, so todo() itself likely needs to be async. Also if todo() takes some time to run, then the sleep time probably needs to be adjusted.
import uasyncio as asyncio
start_ms = time.ticks_ms()
async def task1():
        print(time.ticks_diff(time.ticks_ms(), start_ms), "task 1")
async def task2():
        print(time.ticks_diff(time.ticks_ms(), start_ms), "task 2")
async def task3():
        print(time.ticks_diff(time.ticks_ms(), start_ms), "task 3")
        await asyncio.sleep_ms(2000)
loop.run_forever()
Output:
0 task 1
0 task 2
0 task 3
2002 task 3
4005 task 3
5001 task 1
5001 task 2
6006 task 3
8007 task 3
10003 task 1
10003 task 2
10007 task 3
12009 task 3
14011 task 3
15003 task 1
15003 task 2
16012 task 3
18015 task 3
20003 task 1
Ventran
Post by Ventran » Wed Oct 28, 2020 8:26 am
OK, I use only:
await asyncio.sleep_ms( )
but the Display show only Task #3 (5 sec) and Task #2 (1 sec).
I want show on display Task #1 (during 5 sec.), Task #2 (during 5 sec.) and Task #3 (during 2 sec.)
Post by jimmo » Wed Oct 28, 2020 8:29 am
Can you clarify what you mean...
do you want task 1 for some time. THEN task 2 for some time. THEN task 3? in which case they don't need to be separate tasks
What your code does is run the tasks concurrently - i.e. they're all sleeping at the same time, and if they sleep for the same amount of time then they'll end up updating the display at the same time.
Ventran
Post by Ventran » Wed Oct 28, 2020 11:59 am
Yes.
I want something like this:
    display.text("Task #1", 5, 5)
    display.show()
    utime.sleep_ms(5000)
    display.fill(0)
    display.text("Task #2", 5, 5)
    display.show()
    display.fill(0)
    display.text("Task #3", 5, 5)
    display.show()
    display.fill(0)
but how I can update content in "reall-time" on the display when show e.g Task #1 ?
Post by jimmo » Wed Oct 28, 2020 11:37 pm
Either:
- Don't sleep for the whole 5 seconds at once. Instead loop for the duration of the task with much smaller sleeps until 5 seconds have passed.
start_time = time.ticks_ms()
while time.ticks_diff(time.ticks_ms(), start_time) < 5000:
  do_more_work()
  update_display()
  # maybe a small sleep
- Run two tasks, one that periodically updates the display (similar to above) and another that does the actual work telling the other task what the current state is.
Ventran
Post by Ventran » Fri Oct 30, 2020 6:24 pm
Thank you for you solution. Simple state machine resolve problem.
Three task:
- one for update display
- one for get new value
- one for switching tasks
