Why does my ISR callback work even though I am allocating memory?
solarjoe
Post by solarjoe » Wed Oct 28, 2020 9:25 pm
I have a question and hope that you can help me.
I am reading into ISR callbacks in the Micropython docs at the moment.
(https://docs.micropython.org/en/latest/ ... rules.html)
While the recommendation to allocate memory outside of the callbacks using
array
or
bytearray
makes total sense to me, I could not help but to try what happens if I do that :)
And - everything works like a charm... I have no clue why or if this is some special case.
Can someone enlighten me? I really tried to break every rule I found in the docs and expected Python to complain like hell.
import micropython
a = []
class SomeThing:
    pass
def callback(pin):
    global a
    a.append(True)
    b = 2.2
    x = SomeThing()
    c = 4.4
    print()
    print(pin)
    print(b + c)
p = machine.Pin(39, machine.Pin.IN, machine.Pin.PULL_UP)
trigger_all = Pin.IRQ_FALLING | Pin.IRQ_RISING
p.irq(trigger=trigger_all, handler=callback)
    pass
Re: Why does my ISR callback work even though I am allocating memory?
Post by jimmo » Wed Oct 28, 2020 11:49 pm
It depends which board/port you're using.
On ESP32 for example, all IRQs are "soft" which means they run in the MicroPython scheduler.
In general, the foo.irq(..., hard=) kwarg lets you control whether an IRQ is hard (runs in true interrupt context, no allocations) or soft (not very many restrictions). See http://docs.micropython.org/en/latest/l ... ne.Pin.irq. On ESP32 this kwarg is ignored because it must always be soft, but for example Pyboard/STM32 lets you use either.
solarjoe
Post by solarjoe » Thu Oct 29, 2020 7:09 am
Thanks for your answer, that was new to me.
Pin.irq(..., hard=False)
hard: Hard interrupt handlers may not allocate memory; see Writing interrupt handlers. Not all ports support this argument.
