This is propably one of those stupid questions, but anyways ... is there way to check webrepl status?
I converted my motion sensor script to asyncio and for some reason webrepl, which is activated in the boot.py, is not responsive anymore.
Command: help (webrepl)
gives me:
object <module 'webrepl' from 'webrepl.py'> is of type module
start_foreground -- <function start_foreground at 0x3ffe5600>
__file__ -- webrepl.py
websocket_helper -- <module 'websocket_helper' from 'websocket_helper.py'>
accept_conn -- <function accept_conn at 0x3ffe5390>
setup_conn -- <function setup_conn at 0x3ffe5340>
client_s -- None
stop -- <function stop at 0x3ffe53a0>
uwebsocket -- <module 'uwebsocket'>
__name__ -- webrepl
socket -- <module 'usocket'>
_webrepl -- <module '_webrepl'>
listen_s -- <socket>
network -- <module 'network'>
start -- <function start at 0x3ffe5400>
uos -- <module 'uos'>
so, how do I implement check in the main.py so that I can check if the webrepl is already running? Start I can do with webrepl.start() if not started already.
Asyncio and WebREPL
- MostlyHarmless
Re: Asyncio and WebREPL
It works here, and not only that. I have a picoweb application with 4 additional uasyncio tasks plus webrepl, utelnetserver and uftpd all running happily together on one ESP32.
Are you sure that webrepl is being started? The setup normally just tacks the import and start() at the end of boot.py. If your original boot.py imported main.py AND that main.py import never finishes (because it calls uasyncio.run() for a never ending task for example), then it isn't started. You should then get a "connection refused" if you try to connect to port 8266 via something like telnet or nc.
Regards, Jan
Regards, Jan
I am sure that boot.py start the webrepl, and boot.py and the webrepl works with other async setups like async mqtt.MostlyHarmless wrote: ↑Mon Nov 02, 2020 6:27 pmIt works here, and not only that. I have a picoweb application with 4 additional uasyncio tasks plus webrepl, utelnetserver and uftpd all running happily together on one ESP32.
Regards, Jan
This problem device is different. From USB serial everything seems to boot up and operate normally, but when I reboot with machine.reset() and try with webrepl, no connection and indeed, connection is refused for telnet ip:8266. I will erase flash and try again or use another dev board.
My boot.py:
import utime
import ntptime
import webrepl
from time import sleep
# 0 = power on, 6 = hard reset, 1 = WDT reset, 5 = DEEP_SLEEP reset, 4 soft reset
print("Edellisen bootin syy %s" % machine.reset_cause())
from parametrit import SSID1, SSID2, SALASANA1, SALASANA2, WEBREPL_SALASANA, NTPPALVELIN, DHCP_NIMI
except ImportError as e:
print("Tuontivirhe %s", e)
if (SSID1 is not None) and (SALASANA1 is not None):
SSID2 = None
SALASANA2 = None
WEBREPL_SALASANA = None
NTPPALVELIN = None
DHCP_NIMI = None
print("Vaaditaan minim SSID1 ja SALASANA!")
raise
def ei_voida_yhdistaa():
print("Yhteys ei onnistu. Bootataan 1 s. kuluttua")
sleep(1)
machine.reset()
def aseta_aika():
ntptime.settime()
except OSError as e:
print("NTP-palvelimelta %s ei saatu aikaa! Virhe %s" % (NTPPALVELIN, e))
ei_voida_yhdistaa()
print("Aika: %s " % str(utime.localtime(utime.time())))
def kaynnista_webrepl():
if WEBREPL_SALASANA is not None:
webrepl.start(password=WEBREPL_SALASANA)
except OSError:
pass
webrepl.start()
print("WebREPL ei kaynnisty. Virhe %s" % e)
raise Exception("WebREPL ei ole asenettu! Suorita import webrepl_setup")
wificlient_if = network.WLAN(network.STA_IF)
# Ollaan jo yhteydessä 1, 2 tai 4 resetin vuoksi
if wificlient_if.config('essid') != '':
print("Yhteydessä verkkoon %s" % network.WLAN(network.STA_IF).config('essid'))
print('Laitteen IP-osoite:', network.WLAN(network.STA_IF).ifconfig()[0])
print("WiFi-verkon signaalitaso %s" % (network.WLAN(network.STA_IF).status('rssi')))
aseta_aika()
kaynnista_webrepl()
etsi_lista = []
ssid_lista = []
kaytettava_salasana = ""
kaytettava_ssid = ""
wificlient_if.active(False)
time.sleep(1)
wificlient_if.active(True)
time.sleep(2)
if DHCP_NIMI is not None:
wificlient_if.config(dhcp_hostname=DHCP_NIMI)
if NTPPALVELIN is not None:
ntptime.host = NTPPALVELIN
ssid_lista = wificlient_if.scan()
time.sleep(3)
except KeyboardInterrupt:
raise
except ssid_lista == []:
print("WiFi-verkkoja ei löydy!")
ei_voida_yhdistaa()
except OSError:
ei_voida_yhdistaa()
# Katsotaan löytyvätkö SSID1 ja SSID2 listalta
etsi_lista = [item for item in ssid_lista if item[0].decode() == SSID1 or item[0].decode() == SSID2]
except ValueError:
# SSDI ei löydy
print("Etsittyä WiFi-verkkoja ei löydy!")
ei_voida_yhdistaa()
# Mikäli listan pituus on 2, silloin löytyi molemmat ja valitaan voimakkain, muuten valitaan vain se joka löytyi
if len(etsi_lista) == 2:
# kolmas lopusta on signaalinvoimakkuus rssi
if etsi_lista[0][-3] > etsi_lista[1][-3]:
kaytettava_ssid = etsi_lista[0][0].decode()
kaytettava_salasana = SALASANA1
kaytettava_ssid = etsi_lista[1][0].decode()
kaytettava_salasana = SALASANA2
# vain yksi listalla
# machine.freq(240000000)
print("Yhdistetään verkkoon %s" % kaytettava_ssid)
wificlient_if.connect(kaytettava_ssid, kaytettava_salasana)
time.sleep(5)
except wificlient_if.ifconfig()[0] == '0.0.0.0':
print("Ei saada ip-osoitetta!")
ei_voida_yhdistaa()
except OSError:
ei_voida_yhdistaa()
finally:
if wificlient_if.ifconfig()[0] != '0.0.0.0':
aseta_aika()
kaynnista_webrepl()
print('Laitteen IP-osoite:', wificlient_if.ifconfig()[0])
print("WiFi-verkon signaalitaso %s" % (wificlient_if.status('rssi')))
ei_voida_yhdistaa()
