How to read a file using C language
heiseiggg
Post by heiseiggg » Tue Nov 10, 2020 11:21 am
I'm currently using MicroPython to develop esp32 board. Now I need to read a file in flash in main.c. How could I do this? Could anybody show me an example? Thanks
Re: How to read a file using C language
Post by jimmo » Wed Nov 11, 2020 12:12 am
You can use mp_vfs_open (see extmod/vfs.h) to open the file which will return a stream object, that you can use mp_stream_rw (or mp_stream_read_exactly) to read bytes from (see py/stream.h). You can see an example of this vfs_reader.c (which is what is used by the lexer to load Python files from flash).
This is how builtin "open" works (see esp32/mpconfigport.h where it maps mp_builtin_open to mp_vfs_open).
heiseiggg
Post by heiseiggg » Wed Nov 11, 2020 3:13 am
Thanks Jimmo, Your advice is quite helpful.
What if I want to modify the file from flash with C? Which file could be useful for me?
Post by jimmo » Wed Nov 11, 2020 9:31 am
Exactly the same -- mp_stream_rw
heiseiggg
Post by heiseiggg » Thu Nov 12, 2020 6:40 am
Hi Jimmo, I've got another problem. When I call mp_reader_new_file function, it works well. But if I directly call mp_vfs_open, the "NLR jump failed error" occurs. Could you please help me figure out what might cause this problem? Thanks.
Post by jimmo » Thu Nov 12, 2020 11:54 am
NLR is the way exceptions are handled in MicroPython -- this means that mp_vfs_open is raising an exception which your code is not handling. Here's an example of writing an exception handler in C:
    nlr_buf_t nlr;
    if (nlr_push(&nlr) == 0) {
        // do stuff
        nlr_pop();
    } else {
        mp_obj_print_exception(&mp_plat_print, MP_OBJ_FROM_PTR(nlr.ret_val));
        return MP_OBJ_NULL;
I'm not sure why mp_vfs_open is failing, but perhaps something to point out is that until _boot.py runs on ESP32, there is no filesystem mounted.
Pytri
Post by Pytri » Fri Nov 13, 2020 7:53 pm
Thanks, helped me as well.
