isinstance problem
Posted: Fri Nov 13, 2020 1:29 pm
by atmuc
isinstance returns false for I2C. Is it a bug?
i2c: I2C(0, scl=22, sda=21, freq=400000)
i2c type: <class 'I2C'>
is instance I2C: False
is instance Pin: True
pinSCL = Pin(22,Pin.OUT)
pinSDA = Pin(21,Pin.OUT)
i2c2 = I2C(0, scl=pinSCL, sda=pinSDA)
print("i2c:",i2c2)
print("i2c type:",type(i2c2))
print("is instance I2C:", isinstance(i2c2, I2C))
print("is instance Pin:", isinstance(pinSCL, Pin))
Re: isinstance problem
Posted: Fri Nov 13, 2020 4:34 pm
by atmuc
it returns false with the image esp32-idf4-20200902-v1.13.bin, it returns true with the image esp32-idf4-20201112-unstable-v1.13-160-g8a917ad25.bin
Posted: Fri Nov 13, 2020 6:49 pm
by kevinkk525
Posted: Fri Nov 13, 2020 7:21 pm
by atmuc
I didn't understand the solution from your link. Do I have to use soft I2C?
Posted: Fri Nov 13, 2020 10:13 pm
by kevinkk525
It might not be an obvious solution to your question. The way the I2C classes are handled has changed.
From your code you have been using hardware I2C all the time.
If you check the changes in ports/esp32/modmachine.c from that commit you can see that before this commit the I2C() was the SoftI2C so your code returned false because with id 0 you created a hardware I2C. After that commit I2C() is a HardwareI2C so your code returns true.
Posted: Sat Nov 14, 2020 5:10 am
by jimmo
atmuc wrote: ↑Fri Nov 13, 2020 7:21 pm
kevinkk525 wrote: ↑Fri Nov 13, 2020 10:13 pm
The other commit that explains this is
https://github.com/micropython/micropyt ... 7232b2d101
Kevin's right but just to elaborate a bit to hopefully make the situation a bit clearer.
Before this change, machine.I2C was a soft I2C implementation, however it had some special magic (not very Pythonic -- you could only do this with metaclasses) that if you created it with an ID, then it actually gave you back an instance of the port-specific hardware I2C implementation. (There's no way from Python to get this type, other than to use type() on an existing instance).
So in v1.13
i = machine.I2C(sda=, scl=, ...) --> software i2c, i is an instance of machine.I2C
i = machine.I2C(id, ...) --> hardware i2c, i is an instance of a hidden hardware I2C type
This is why instanceof returns false. Despite being constructed via machine.I2C, it's actually a different type.
The commit I linked to, followed by the one Kevin linked to makes it so that the behavior is inverted (and v1.14 onwards) and adds a new "machine.SoftI2C" (replacing the old machine.I2C), and then "machine.I2C" is now that port-specific hardware i2c type.
i = machine.I2C(sda=, scl=, ...) --> software i2c, i is an instance of machine.SoftI2C
i = machine.I2C(id, ...) --> hardware i2c, i is an instance of machine.I2C
So... you don't need to change your code to use software I2C. But now (as of soon-to-be-released v1.14) you have the ability to tell the two types apart.
Posted: Sat Nov 14, 2020 8:00 am
by atmuc
Thanks. it works now. This code makes esp32 crazy. I have to erase and flush esp32 after this code run on it.
i2c= I2C(0, scl=18, sda=19, freq=400000)
print("i2c:",i2c)
i2c.init(pinSCL,pinSDA)
print("i2c:",i2c)
Posted: Sun Nov 15, 2020 4:34 am
by jimmo
atmuc wrote: ↑Sat Nov 14, 2020 8:00 am
Ah yeah that definitely won't work. init() will end up calling into the software implementation (which isn't initialised). This is a bug -- I will raise it on github.
Posted: Sun Nov 15, 2020 4:39 am
by jimmo
